Plex not picking up media when on external 1TB drive (Raspberry Pi 3B+)
Hi everyone.
I’m having trouble setting up a Plex Server on my RPi 3B+.
The media server picks up the folders/movies when adding the library folders but when I scan the library folders for new content nothing appears in my library.
I have followed this tutorial: Using EXT, NTFS, or other format drives (internal or external) on Linux
But I get the same results.
I have also tried:
  • Giving the external drive 777 permissions
  • Changing the drives owner to plex (changed it back to pi once it didn’t work)
  • Restarted the Pi after permissions and change owner commands were run
  • Tried a different port on Pi for external drive
I can’t seem to find a way around this and it’s starting to get a little frustrating.
Any other ideas on what could be the issue?
See if user ‘plex’ has read permissions to the directory where your media is mounted. For example, my media is stored on an SMB share which I have mounted at /mnt/cifs. So, to see if ‘plex’ can read it:
sudo -u plex ls -l /mnt/cifs
Replace /mnt/cifs with your mount point. Also run the command on the sub-directories within. So my movies are stored in “Movies” on that share:
sudo -u plex ls -l /mnt/cifs/Movies
If ‘pi’ owns the media files, make sure that ‘plex’ is a member of the ‘pi’ group. Run:
groups plex
The output will be the list of groups of which ‘plex’ is a member. Make sure ‘pi’ is listed.
If all that checks out (‘plex’ can read the files/directories of the media and is a member of ‘pi’) you may want to check your library configuration. Plex is picky about library types. So, TV content should not be stored in a “Movies” library, and vice versa.
I managed to fix it by changing the scanner from Plex Movies to Plex Video Files, it then found everything on my drive.
