Server Version#: 1.18.0.1944
Player Version#: 1.3.1.916-1cb2c34d
I am running Plex Media Server on a Raspberry Pi 3. I know the server is running, because I can see it on my Plex app on my Mac.
I’ve added some media to a USB flash drive to test the system. The drive is formatted to exFAT, and I have installed the exFAT drivers on my Pi. Raspbian recognizes the drive and can read and write files to it.
When I set up a library using the Plex app, it doesn’t see that there are files in it. I get the message, “This library is currently empty”
What do I need to do to make Plex see my files? Is the problem exFAT?
Verify the server is running (obviously) ps -ef | grep -i plex
open an incognito window to either 127.0.0.1 (if same machine) or IP of the machine on your LAN (same subnet) or ssh-tunnel to it if remote or different subnet.
Hello @ChuckPa, thank you for responding. I am very new to Raspberry Pi and Linux in general, so it might take me a while to understand everything.
Plex Media Server is running on my Raspberry Pi. I’ve tested it by copying a media file directly into the /media folder on the Raspberry Pi’s SD Card. I made a Plex library and pointed it at /media and I can play the file on any Plex player I have.
Now I’ve plugged in an external hard drive I was using with Plex before, when I had Plex Media Server running on an old MacBook. The MacBook has died, so I am trying to replace it with the Raspberry Pi. On the Raspberry Pi it mounts as /media/pi/Plex Media. I see this in Raspbian File Manager. But Plex doesn’t see the folders within (which contain the media) when I try to add it to my library. This is the permissions problem, right?
What is the exact command I would use to grant permissions to /media/pi/Plex Media so that Plex Media Server can see all of my files? I can ssh to my Pi, or do it directly in Raspbian. I’ve learned that much!
