Server Version#:1.18.02
Player Version#:1.4.0.924-60046db9
When i play a movie (on MY Laptop Connect To TV Via HDMI) that have audio in EAC3 codec it bypass that to TV and No audio output .Help me how to fix this .
Try this instead software player (Plex Media Player); go into TV Mode and then Settings to adjust audio as needed.
The player you currently have installed on your laptop is for simple playback when NOT connected to a TV.
Thanks for reply i have download the software i will check with my tv after that i will update you ,i got fealing that it will work now.
Can you tell me if any option avilable for Chromecast i want 2.1 audio on that also my volume control not work when i play any 5.1 audio chromecast send audio to TV and my speakers play in full volume .
I’m afraid I don’t have any experience with Chromecast.
No problem, Its works as you say i download Plex Media Player and it works no need to change settings it just work.
