Plex not recording: showing no upcoming airings
Continuing the discussion from Plex not recording: showing no upcoming airings:
So… I tried it again, after deleting the DVR, signing out, signing in, re-installing the DVR, re-scanning the channels, re-downloading the EPG and re-checking the recording settings.
Same result: the guide shows the little white dots on a read rectangle, suggesting there’s a recording going on (but the activity indicator shows nothing), and the calendar view shows the planned recordings , but with “no upcoming airings”.
When I go in and press the record button while watching a show, the recording is also not saved. I can only spool back to the moment I pressed the record button, but if I leave Plex and return later, there is no recording.
Any suggestion is welcome - I am a paying Plex member, mainly because I use this function…
Cheers,
P.
