Plex not saving original settings?
I have a new 512 Model B Pi with a Class 10 SD card and running 1.37 over Wired Network, everything runs smooth as silk from first install and setup but after I select Shutdown when I unplug the Pi and plug it back in, there is nothing listed.  If i check the settings through Preferences, all my settings are there but the PMS does not load.  It also does not show up on my iOS remote app.
I have tried multiple restarts / multiple power adapters  the only resolution I have right now is to reflash and go through setup again.  I tried going through setup and leaving it on overnight to cache and then (without playing anything) restarting, same problem.  It seems as though my settings are not being saved.  Please help if you know anything I am doing wrong.  IT works fine for a few days if I don't shutdown or unplug but eventually it will lock up and i have to Hard Restart....
Thanks in advance and very grateful for this software, I would just like to be as happy a user as everyone else is.
