Server Version#: 1.31.2.6810
Player Version#: Chrome
I have a external disk thats mounted as /mnt/filmy/Filmy “Filmy is a root path of the drive” there is a folder ( novinky 2022) containing a 43 Movies (mkv, mp4)
And plex only shows 24 and if renamed some they continue to disappear…
In the server logs it says this:
Mar 19, 2023 16:21:14.757 [0x7f8734f11b38] Ladění — Scanner: Processing directory /mnt/filmy/Filmy/novinky 2022 (parent: yes)
Mar 19, 2023 16:21:14.774 [0x7f8734f11b38] Ladění — Skipping over directory 'novinky 2022', as nothing has changed; removing 43 media items from map.
Afaik it just skips it and i dont know what is wrong…
PowerRenamer in Microsoft Power Tools is helpful for simple renaming with pattern matches or regular expressions. It makes quick work of tasks such as adding a year to file names, removing undesirable text from multiple files, etc
If you have Plex pointing at the Filmy folder it probably thinks “novinky 2022” is an actual movie
When it comes to movies Plex does not support multiple sub-folders. Sometimes it works, sometimes it doesn’t
All of those movies should be inside the Filmy folder (eliminating the novinky 2022 folder)
OR
You have to move the Novinky 2022 folder outside of the Filmy folder and point Plex directly at it
You have to make sure all the movies inside the novinky 2022 folder are named following the guidelines Fordguy outlined. The minimum requirement for this is the the movie name and date in parenthesis
