Plex not showing all trailers
Hi my plex media server is not showing all trailers and I have the youtube metadata agent I optimize database refresh metadata and scan library files clean bundles
I dont know how to remove offending files what can I do
What do you mean by it’s not showing all trailers? Like you have the client set to show 6 and it’s only showing 3? or?
Some movies dont have trailers available what can I do I got youtube agent plex movie checked
local media assest checked the movie database checked the tvdb agent I want to know if theres a way to add those trailers manual without download them
trailers are set in the plex client, but enabled on the server… So you need to do 2 things:
Server side:
Settings>Extras
  • Select whatever combination of things you want it to do
Client side:
Settings>Experience>Cinema Trailers to play before movie (Choose a number)
*Note: Each client is slightly different, the above was taken from Android TV
