Plex not showing artwork on smarttv only
Server Version#: 4.123.2
Player Version#: 5.77.1
Artwork is shown on my computer but not on tv. It comes up as a grey background with title in the middle. It has only started doing that this Monday.
Any solutions?
Fixed:
Alright, so it looks line I found the culprit on mine. I was setting up my router settings to be more secure and enabled the DNS rebind protection. This doesn’t work well with plex app when it tries to comunicate with the server. Setting it back to default rwstored the artwork.
DNS rebinding protection as such is a good thing.
If your router allows you to define a list of domains which are excempt from the protection, you should add plex.direct to it – and leave the protectio enabled.
The technical background is explained in https://support.plex.tv/articles/206225077-how-to-use-secure-server-connections/
