Plex not showing TV Show Directory
Server Version#: Version 1.40.2.8395
I have a synology NAS server with plex on it I added a new drive / formatted it NTFS
Created a new share called TV
Then in plex tried to add the new local folder: /volume2/TV
It will not populate what am i doing incorrectly / Movies and music work perfectly
Perhaps this?
(DSM 6 = “Plex”, DSM 7 = “PlexMediaServer”)
It has the same permissions as the other folders.
When you set permissions on the shared folder for “System Internal User” (NOT local user) PlexMediaServer,
Did you also check the box “Apply to this folder, sub-folders and files” ?
(Plex is not a privileged program. You must expressly give permission to everything in the shared folder because of how Synology ACLs work)
Thank you the upgrade was it. I had give the system permission as well this time,
Seems to be working now thanks
When we upgraded from DSM 6 → DSM 7,
  1. Complete rewrite of the packaging
    – You will notice you have a menu now in the packsge.
    – You can claim the server as you install it.
  2. Plex shared folder – Abandoned.
  3. Plex user – Abandoned.
  4. New special shared folder and System Internal User (Synology’s new rules)
