Thanks. I did plan on researching it and fixing it when I get a chance. I assume you’re talking about the 802.3ad and not just the fact that I’m port trunking the connections. I probably don’t need as much bandwidth as I have available but probably more internally than one port will provide. The QNAP came with two ports and my m.2 expansion card just happened to have 2 more so I have them all hooked up since I have the ports.
Hello,
Completeley uninstalling Plex Server, reboot the NAS and reinstall Plex Server (and reconfigure everything from scratch…) solved the issue on my side.
No so cool, but better than nothing…
Thanks and regards,
Patrick
