Hello
Today i went a got myself an lg led smart tv with webOS 3.0 so i could use my plex pass on my tv. before i got the tv i checked the plex support page and it said plex is on webOS 1, 2 & 3. so i got the latest 2016 LED screen, and wow im so disapointed
cant seem to find the plex app on the download page, i can cast plex from my tab or pc to the tv built in wifi.
so what am i doing wrong? i just spent £349 on a new tv that does the same as my old one.
please could someone direct me on what to do. do you think i can take tv back if there is nothing wrong with it? or am i looking in the wrong place for the app
thanks in advance
Doyle
which model number is it?
There is a version of WebOS called WebOSlite and another called Simple Smart which our app is not available on currently ( but we are working on getting it on those too )
hello thanks for the speedy reply.
the model of tv is:-
LG 43LH604V 43 Inch Full HD WebOS Smart LED TV.
the actual listing is argos.co.uk/static/Product/partNumber/5248843.htm#pdpFullDesc
the listing just says WebOS.
on the tv it says webOS TV Version is… 3.0.0-16622 (dreadlocks-deathvally)
software version …03.00.85
hope my info helps solving this problem
thanks
it should be on that TVwhen you search their store. not sure why it would not be. on LGs site it says WebOS3 http://www.lg.com/uk/tvs/lg-43LH604V
I know I just went to the app store and searched for plex and it was there, also an app called xplay, which is a community made player.
Maybe make sure your webOS/tv software is up to date, don’t think the app store filters by compatibility, but who knows
May I please know why the app is freezing and consistenly hanging on the LG TV 2016 model?
hi again, thanks for the reply’s…
I spent ages going through all the store and cant find plex or xplay, when i search all i get is you tube videos about plex.
i went to the system menu to see if i could update the TV, and it just says no update available. would it be anything to do with the country. as when i set the TV i selected UK. would changing that do anything?
thanks in advance
Doyle
Hold on line to me get my magic 8 ball…
In all seriousness, the developers will need logs if you want it diagnosed.
please make a new thread. by hitting the Ask a Question button and provide details of when it is freezing what is the app doing
thanks in advance
Doyle
we do not region restrict the app but i guess it is worth a try if nothing else is working.
( seems odd the app store is showing you youtube results )
