Plex on Roku scrolling issues
Server Version#: 1.32.5.7210
Player Version#: 7.4.2.8452 AND 7.5.0.8476 (preview)
With a single scroll click on the D-pad of a Roku remote, the selection jumps multiple tiles. Is this related to the ‘speed scrolling’ bug that should have been addressed in the preview version - 7.5.0.8476? We are seeing this issue with both the current public and preview versions on the Roku platform.
Exact same issues here.
After much testing with multiple Rokus, I found that simply restarting the Roku corrected this issue. It must have something to do with resource utilization over time affecting that input. Anyway, mystery solved … “Have you tried turning it off and on again?”
Even though the workaround may work, it is still only a workaround. This is still a bug that requires fixing.
I hate this bug, my Roku does the same thing when I try to program the DVR. It’s very annoying!
I have the same issue with the latest build. Please provide a fix. Thanks.
Reboot your Roku and that should correct it.
