Iāve noticed that the Plex interface speed on my 2018 Tizen Samsung TV has become significantly worse in the last several months. The performance now is downright laughable - it takes upwards of 10 seconds just to load a basic screen. Meanwhile, other apps on my TV, like Apple TV and Netflix, run as smooth as butter and everything loads instantly. My Plex server is connected to the same local network so thereās no latency or bandwidth issue. Videos play fine, no problems there. Itās just the interface is achingly slow. I donāt know what āfeaturesā the Plex client devs have been adding, but please take them out, since the interface is almost unusable at this point. Iāll take responsiveness over features any day of the week. Hopefully they fix this soon!
Iām sorry, but I have to be straightforward: this is due to poor programming. When I bought the LG OLED B9, the Plex app was smooth and fast (version 4.x I believe). It was only after there was a major update of the Plex app that this happened. And donāt tell me itās due to the weak processing of the TV because all other apps work well, including Plexās competitors. What is clear is that this problem is clearly not a priority; or they donāt have the right programmers (which doesnāt seem to me).
Yeah ok this is now beyond help. The app is simply unusable. It took 30 seconds for it to load and every key press takes 10 seconds to take effect. Does it mine Bitcoin? What the ā ā ā ā is it using my TV for? How can a single app be SO slow? Especially when every other app functions perfectly fine. This is ridiculous.
I really wish they would do something about the performance of the app. Nice features keeps coming in but the performance is getting worse and worse. I wish itās as smooth as it was back then, like how consistently smooth Netflix and other related app are.
Personally I donāt expect it to be as slick as Netflix. Weāre not comparing apples and oranges.
BUT the speed of responsiveness and level of support needs work.
Is there a bug fix work timeline anywhere?
Any news on whats going on with the plex client getting slower and slower after each update
I see new features are being added but old issues are just being left as per usual
I rather plex gave an option and made a lite version of the app for us who dont want all these extra fancy features to keep the app running fast and smooth
There is no single fix that will solve all the performance issues. Performance fixes are incremental because there are multiple pieces contributing to the performance problems and we are tackling them when we can. Itās a matter of getting the resourcing to spend more time on it. Itās important to us though, and even though we arenāt always replying on this thread, performance is always something we are discussing and looking at internally.
What Iām getting from this comment is that weāre not getting any fix for this, ever.
While the contributing factors to the current performance issues may be many, it DID happen overnight. There most definitely WAS a version over a year ago that was working perfectly fine before you changed something and either you donāt know what that is or it was a fundamental change you canāt go back on.
I kinda agree at this point that unless the performance is fixed there is no point in continuing to develop for these platforms.
@sLumpy you may as well pack up and head home if this is as good as the performance gets honestly, because no one is bothering with the Samsung Tizen Platform and Plex anymore. Why bother updating it? (Which is what you support) going forwards.
Saying there is any Plex support for Samsung Tizen OS is a joke at this point, and Plex keeps adding features we donāt care about or plan to use. The primary use case is to stream from my media library to my Samsung TV and Plex canāt even do that right anymore.
At this point Iād recommend scrapping everything since the last official Plex Preview, or at least re-upload the preview .tmg files so we can rule out an App specific issue?
For anyone wondering you can sideload the Plex app to your Samsung TV with the following steps (assuming Plex gives us one of their old archived copies to troubleshoot this):
Instructions:
Uninstall the existing Plex application
Download the .zip release above
On your USB stick, create a folder called userwidget
Unzip the contents of the .zip file into the userwidget folder you just created
Turn on the TV
Plug in the USB drive into your Samsung UHD device. Installation should start automatically.
Run the App from your Smart Hub, or from the App store.
