Plex on Samsung smart TV - file format not supported
Hi, I have a couple of samsung smart TVs neither of which are able to play mkv format via plex server with error “format not supported” and showing the mkv format as vnd.dlna.mpeg-tts. But both of them can play that very same format if I were to play it via a shared folder on my network or if I use the plex app on either of the TVs. Is there a way to work around this issue? If so some guidance would be much appreciated. Log below trying to run a large mkv movie
Server Version#: 1.15.3.876
LOG:
May 09, 2019 21:36:43.883 [7448] DEBUG - Scaled up video bitrate to 35023Kbps based on 1.500000x fudge factor.
May 09, 2019 21:36:43.883 [7448] DEBUG - MDE: Selected protocol http; container: mpegts
May 09, 2019 21:36:43.883 [7448] DEBUG - MDE: analyzing media item 11923
May 09, 2019 21:36:43.883 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no direct play video profile exists for http/mkv/vc1
May 09, 2019 21:36:43.883 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no direct play video profile exists for http/mkv/vc1/ac3
May 09, 2019 21:36:43.883 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no direct play video profile exists for http/mkv/vc1/dca
May 09, 2019 21:36:43.884 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no direct play video profile exists for http/mkv/vc1/ac3
May 09, 2019 21:36:43.884 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no remuxable profile found, so video stream will be transcoded
May 09, 2019 21:36:43.884 [7448] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 09, 2019 21:36:43.884 [7448] DEBUG - Scaled up video bitrate to 35023Kbps based on 1.500000x fudge factor.
May 09, 2019 21:36:43.884 [7448] DEBUG - MDE: The Lord of the Rings: The Fellowship of the Ring (2001): selected media 0 / 11923
May 09, 2019 21:36:43.901 [10176] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/timeline?containerKey=%2Flibrary%2Fmetadata%2F4392&duration=6227605&guid=com.plexapp.agents.imdb%3A%2F%2Ftt4073790%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F4392&ratingKey=4392&report=1&state=stopped&time=1000&X-Plex-Device=Samsung%20SmartTV&X-Plex-Device-Name=Samsung%20SmartTV&X-Plex-Product=DLNA&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
