Server Version#: n/a
Player Version#: 8.6.0
Since the latest 8.6.0 update I can’t play anything on my Shield TV Pro (latest gen). Reinstalling the app etc makes no difference.
As soon as I start playback, the app closes. This happens with any type of content, including Plex’s own content or my content.
Logs:
09-09 15:25:41.295 i: Fetching [method:GET] https://vod.provider.plex.tv/library/metadata/5f0e67f12e629900401c0624?asyncAugmentMetadata=1&checkFiles=1&includeExtras=1&includeReviews=1&X-Plex-Token=...FAbM
09-09 15:25:41.632 i: Fetching [method:GET] https://vod.provider.plex.tv/hubs/metadata/5f0e67f12e629900401c0624/related?count=20&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...FAbM
09-09 15:25:41.765 i: [ImageTranscodeBuilder] Unable to transcode request
09-09 15:25:41.776 i: [ImageTranscodeBuilder] Unable to transcode request
09-09 15:25:41.780 i: [ImageTranscodeBuilder] Unable to transcode request
09-09 15:25:42.691 i: [OneApp] User can execute command without restrictions because he is entitled.
09-09 15:25:42.705 i: [PlaybackManager] Preparing for Croc
09-09 15:25:42.730 i: [DefaultPlaybackManager] No codecs being downloaded.
09-09 15:25:43.547 e: Fatal exception occurred.
09-09 15:25:43.547 e: An exception occurred: java.lang.RuntimeException: Canvas: trying to draw too large(132710400bytes) bitmap.
09-09 15:25:43.547 e: Stacktrace: java.lang.RuntimeException: Canvas: trying to draw too large(132710400bytes) bitmap.
at android.view.DisplayListCanvas.throwIfCannotDraw(DisplayListCanvas.java:229)
at android.view.RecordingCanvas.drawBitmap(RecordingCanvas.java:98)
at android.graphics.drawable.BitmapDrawable.draw(BitmapDrawable.java:545)
at android.view.View.getDrawableRenderNode(View.java:20486)
at android.view.View.drawBackground(View.java:20422)
at android.view.View.draw(View.java:20221)
at android.view.View.updateDisplayListIfDirty(View.java:19105)
at android.view.View.draw(View.java:19958)
at android.view.ViewGroup.drawChild(ViewGroup.java:4333)
at android.view.ViewGroup.dispatchDraw(ViewGroup.java:4112)
at android.view.View.updateDisplayListIfDirty(View.java:19096)
at android.view.View.draw(View.java:20233)
at com.android.internal.policy.DecorView.draw(DecorView.java:792)
at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:686)
at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:692)
at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:801)
at android.view.ViewRootImpl.draw(ViewRootImpl.java:3505)
at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:3309)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2603)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1538)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7520)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:949)
at android.view.Choreographer.doCallbacks(Choreographer.java:761)
at android.view.Choreographer.doFrame(Choreographer.java:696)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:935)
at android.os.Handler.handleCallback(Handler.java:873)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:193)
at android.app.ActivityThread.main(ActivityThread.java:6721)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
