Plex outage?
This morning I noticeed my Plex server has a yellow triangle next to my name in General setting. (No tooltip saying what that meant.) Remote access was offline for some reason.
Figured I would sign out and reconnect. Sign out ok. Try to claim server and the claim server button isnt working at all.
Try to sign into Plex webapp and everything is super slow.
Anyone else
More info here https://status.plex.tv/ :wink:
I am having a similar issue that also just started this morning.
I can login but after that all I get is the follow:
Plex is not reachable.
Make sure your server has an internet connection and any firewalls or other programs are set to allow access.
I have changed nothing and I have access to the internet with all other applications.
same here
Same, it just took me 10 minutes to be able post this reply kept getting Gateway Error. Only one of my Home Users is showing up on my apps and it’s not even mine. I was able to login to the webapp but remote is down and clicks fail intermittently.
Same here. Is there a problem with the authentication of the plexpass-users?
Seeing he same issue here.
Plex post this on their status.plex.tv page.
Investigating - We are investigating issues with slow responses and timeouts from the authentication and API server.
Mar 27, 08:37 PDT
same here on the android app but web app work fine , and please :pray::pray: fix this to There is no play or pause button or any button when playing a video!
Yep…down on my end too. After launching the server it tries to connect…and terminates after spinning its wheels for a few minutes. Initially thought the server might be the issue but when I went to plex.tv to grab the latest update, downloads were unavailable.
Wasn’t even able to login to the plex forums until just now. Both plex.tv desktop and mobile down for me. Something with the authentication server.
This just shows how tied to Plex servers the application is. I really want an application I run locally to work locally.
Might be time to investigate a more independent solution.
Down for me too. It took me about 5 minutes just to get logged in to reply here.
Annoying that something installed on a computer in my home and accessed by devices in my home, is dependent on servers outside my home.
Yes I can use localhost:32400 on the server, but when I try IP:32400 it goes to /web/index and then fails.
How can I bypass the internet and connect to my server from other machines on the same network.
Websites, Apps, (Shield TV Client) etc.
Have been having (Log-In) issues for several hours…
Plex just resurfaced now…
Mines back and working now. just come back in the last couple of minutes.
Same Here !!!
still dont work for me.
Anyone else ?
