Plex Pass - Question about DVR
When using Plex Pass, will I be able to use my HD Homerun Tuner with the DVR functions? There used to be a plugin called HDHR Plus, but with the discontinuation of plugins, it no longer works. Does the Plex Pass DVR Function replace this?
Can I use this DVR function on my mobile devices?
Thanks you.
I don’t know about hdhr plus, but yes plex pass enables live tv and dvr with hd homerun and other compatible tuners.
I have a HDHR quad.
It is not necessarily perfect, but it does the job.
I would suggest you try the plex pass 30 day trial, or buy 1 month to make sure it works to your satisfaction.
you can find more info about dvr/live tv @ https://support.plex.tv/articles/?s=dvr&search=support_articles
Thanks, and can I use this on my iPhone or other mobile device that has Plex installed? (The plugin was called HDHR Viewer 2 - my mistake.)
And thanks for the 30 day trial suggestion. I will do that.
sure can
of course you will need sufficient internet speed between your server and phone or other clients.
also server powerful enough to handle any transcoding if needed.
