Plex pass
Hi im a new user to plex pass I just sign up and unable to access it
Shut down your Plex server(s) for a few minutes. Then start it up again.
Same with your Plex client devices.
That way they are forced to contact plex.tv and get informed about your new Plex Pass.
Thank you
im getting this error
Your server is signed in to Plex, but is not reachable from outside your network. Learn moreTip: It looks like your server may be connected to the internet through multiple routers or other network devices. Try connecting it directly to your primary device, or visit our support site for more information about troubleshooting this “Double-NAT” scenario
You currently have Remote Access enabled through a manually-specified port. If you wish to disable Remote Access, you will need to remove your manual port forwarding from your router.
That is only affecting remote access (and it might be a false error anyway)
Can you now access all your server’s settings again?
i can access plex but not being enable to access it away from the network
i have a linksys wrt1200ac router can u help me
Which of your servers are you trying to access remotely?
Did you already create portforwardings in your router?
How many routers (or similar devices) do you have in your network?
can help me remotely
i have a modem and linksys wrt 1200ac
I don’t do remote sessions, sorry.
Is your modem really just that – a modem? Or is it a router on its own. In this case you’ll either have to
  • switch the modem it into ‘bridge mode’
  • create a manual port forwarding in both devices
i don’t know how to switch modem to bridge mode
the modem also have a wireless connection
Then I am pretty certain that it is a “router” in its own right.
Try to get a user manual for it.
can you download team viewer and help me out
Sorry no, I don’t do that.
ok thank
