oops. thanks.
from 2018:
“Using latest firmware 2.1.3.4.
RBR50 is in Access Point mode wired to my ADSL router (Fritzbox 7390)
Anything attached to my RBR50 (main) either wired or wireless is able to use UPNP port mapping to automatically setup port forwarding from my main router.
However anything atatched to my RBS50 (satellite) is unable to setup UPNP port mapping to the main router.
I have moved the same devices from the main unit to the satellite and back again to verify and re-recreate the issue. I have verified this with PLex and the linux command line utility ‘upnpc -l’
I assume the Orby wifi backhaul is losing the multicast UPNP commands?
There doesn’t seem to be any settings to alter this behaviour in Access Point mode.
I was on firmware 2.1.2.18 until today when I tried upgrading to the latest firmware as above. I am not sure when this issue started.”
is this my issue? i found this on the netgear thread, the solution is to “I have disabled ‘enable daisy chain topology’ in my Orbi router advanced wireless settings. UPNP now works perfectly”
please excuse my stupidity
no i do not - i have it plugged into the router
i just wasn’t sure if that daisy chain topology setting had anything to do with anything.
i am currently following those above instructions - just waiting a few minutes after the plex restart - i deleted the preferences
server setup page
“great we found a server”
i clicked next - i see my libraries and the option to add new…
“All set! Your Plex Media Server is working hard to find your media and make it beautiful. Grab the Plex app for all your favorite devices to get the most out of Plex and start streaming everywhere!”
is this good? should i click done?
i think its good? i mean i assume my preferences will need to be changed, i’m not sure what settings i had changed over the years -
no libraries are currently shared - and remote access is off.
i’m changing to manually specific port?
i can’t thank you and @ChuckPa enough!
should i have either of these enabled?
Enable Plex Media Server debug logging
Enable Plex Media Server verbose logging
awesome! I did not end up disabling the daisy chain - should i send over my logs again to see if you still see that double router issue?
probably a dumb question - but if i compare the new preferences file and the old one i saved a copy of will i be able to compare differences to get some idea of what settings i had?
Enable server support for IPv6 is checked - is this right?
ahh i’m sorry
i’m also a little concerned about all these scheduled tasks - perhaps there is another thread i should look for optimized settings on.
thank you so much and thank you @ChuckPa
if you guys can dm i’d love to buy you lunch or something!
Thank you!!!
i’m sorry, should i send logs one last time to check the double router?
