(I’m sorry to open a new discussion I feel like Synology issue looks different)
Next to Plex mail I have changed my password. Since that time no way to get my DiskStation back in Plex media library !
I have a DS918+ running last DSM7.
I have tried to restart several times the service : no success.
I have tried to connect via http://my-local-ip:32400/web/ : no success.
I have tried via https://app.plex.tv/ : no success.
I have read some posts speaking about “re-claiming” but I’m never able to get that option !
I’m now wondering if I have to uninstall/reinstall Plex Server on my Synology : but to be able to do that I need to find the corresponding Plex server installation package (all the ones I have found on their site contain DMS6 in their file name, so I don’t believe this is the correct file).
This has happened to me and I don’t know what to do. I have tried all the possible fixes online and still don’t have access. Any help would be appreciated
I finally found out how to do it on mine. Im using a Synology with docker. I had my server set to require secure connections which i feel did the worst damage when trying to get back in. I modified the preference file itself so that the secureConnections string was set to 1. After that, open an incognito page and go to your local ip: http://ServerlocalIP:32400/web. This then showed my server without me being signed in. I was able to then go to Settings, General, and then claim. It asks you to sign in and will spend a few minutes claiming then
By official package if you mean the one provided by Synology : than no it isn’t synology package.
It’s already to “1” (I feel like “1” sounds as “true”. Anyway I tried with “0” and result looks the same.
I feel so stupid having changed my password (as I always had the 2 factor identification)
I don’t have kept the installation package
(it was the very last Plex server version for DSM7). As explained in my very first message I have not been able to find it back .
I have a DS916+ and I can access my Plex via private IP, public IP, mobile app, and Roku, but not via app.plex.tv
I get the error app.plex.tv is unable to connect to “myserver” securely
Wondering why it’s just with the web app and no other devices.
After spending a day fixing a broken server, I found the best way to fix it was to not change my password and restore to a backup of the server preferences.
