Plex Password change on a synolgy
Server Version#: ds918
Player Version#: up to date 1.19.3 (up to date)
I changed my plex password after getting an email notice of a new (unknown) login.
I selected the log out of all devices options.
When i logged back in the server wasn’t available.
i tried all four steps on the Why am i locked out server settings page -
a couple differences were found in the xml file:
the online home value was 0 not 1
and the plex online token was empty quotes “”
currently i restored the original xml and hope to be able to fix this.
thank you all
Did you use this one?
i’ve tried that now (using the original xml file) and after step 16 what appears on the side bar is:
home
movies & TV (plex media not personal media)
“PLUS SIGN” your media
more>
i did not get the “we found a new server” message
ps: i had originally tried restoring the the xml file and changing my password back, i was also downloading the xml files and editing them on my pc and reuploading them…what should my worry level be? because i’m bugging out.
When you change the password, the PlexOnlineToken is changed.
Even if you change your password back to its previous value, the Token will change again. Your Preferences.xml file and Plex.tv will not match.
If FAQ #16 did not work then a step was missed or there is something else wrong.
Would you please scroll up to the top of the FAQ and manually collect the log files to attach for me?
I am concerned you missed a step in the process. Hopefully the logs will show us what happened.
Logs.zip (1.0 MB)
I’m pretty sure i uploaded the logs correctly (i deleted the zip file from the plex media folder after downloading it)
hopefully these logs will help.
thanks!
Thanks for the logs.
It looks like you have a router stacked behind a router ?
May 12, 2020 15:30:54.497 [0x7ffa87fff700] DEBUG - NAT: UPnP, found device <http://192.168.1.3:80/Public_UPNP_gatedesc.xml> with private address <192.168.1.7>
May 12, 2020 15:30:54.562 [0x7ffa87fff700] DEBUG - NAT: UPnP, usable device <http://192.168.1.3:80/Public_UPNP_gatedesc.xml> with private address <192.168.1.7>.
May 12, 2020 15:30:54.592 [0x7ffa87fff700] DEBUG - NAT: UPnP, public address is 192.168.1.3
May 12, 2020 15:30:54.592 [0x7ffa87fff700] DEBUG - PublicAddressManager: got WAN IP 192.168.1.3 from router
May 12, 2020 15:30:54.592 [0x7ffa87fff700] WARN - PublicAddressManager: WAN IP is a private IP address
May 12, 2020 15:30:54.593 [0x7ffa87fff700] DEBUG - HTTP requesting GET https://104-229-29-111.5d70494ab86740148639f58828c61382.plex.direct:32401/identity
May 12, 2020 15:30:54.593 [0x7ffa87fff700] ERROR - Error issuing curl_easy_perform(handle): 7
May 12, 2020 15:30:54.594 [0x7ffa87fff700] WARN - HTTP error requesting GET https://104-229-29-111.5d70494ab86740148639f58828c61382.plex.direct:32401/identity (7, Couldn't connect to server) (Failed to connect to 104-229-29-111.5d70494ab86740148639f58828c61382.plex.direct port 32401: Connection refused)
May 12, 2020 15:30:54.650 [0x7ffa8ca94700] DEBUG - HTTP 401 response from GET https://plex.tv/media/providers?X-Plex-Token=
May 12, 2020 15:30:56.016 [0x7ffa858b9700] DEBUG - Request: [127.0.0.1:55922 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo3CmRpY3QKbGlzdApkaWN0Cmxpc3QK
At this point,
  1. Open https://app.plex.tv
  2. Authorised devices (left side)
  3. Servers drop down
  4. REMOVE the Synology entry
  5. Sign out of Plex/web (Upper right corner)
Stop Plex
Now open File Station -> Plex share -> Navigate down into Plex Media Server
Rename Preferences.xml to Preferences.xml.old
Now to make it start back quasi-fresh
  1. start Plex
  2. Open an INCOGNITO window to http://ip.addr.of.syno:32400/web
  3. It will greet / Got It / Sign in.
  4. When it asks to create a new section - SKIP this - Your existing sections survive.
  5. You’ll need set the preferences again so set appropriately when asked.
  6. When you arrive at the Dashboard. you’re done.
i don’t think i have a stacked router - i have an orbi voice set up and the synology nas is plugged into the router - i set it up a few days ago.
i will attempt these steps you’ve sent now, thanks.
when i open plex and navigate to the authorized devices setting - i do not have a servers drop down.
i will stop here for now until directed otherwise
When signed into http://app.plex.tv
You do not have Settings - Authorized Devices ?
There should be a dropdown which allows you to see ALL or Servers.
it was there when i originally did those steps 1-16 that you first posted. but after step 16 it is gone.
i will try now:
1: running plex from DSM
2. going to http://app.plex.tv - when i click settings i have (on the left) account, online media sources, authorized devices, webhooks, users and sharing. plex web, general, debug, player.
3. when i click authorized devices i have chrome 4x and 1 ios (iphone)
there is no server drop down? can i dm you a question?
i can select “your media” and there is an option that says “get plex media server”… i’m scared to press that because i have a large library with a lot of customization. starting over would be less that ideal, i’m already worried about getting the settings back to optimal but hopefully that’s even an option
hello @dane22 and @trumpy81 - i’m having an issue stemming from changing my password, i attempted to change the preference xml as described above but have run into some issues - per @ChuckPa 's help - i tried running claimit but was “unable to connect to remote server”
i’m not sure where to go from here, but hopefully one of you can help.
thanks
absolutey- fresh logs attachedLogs.zip (14.1 MB)
192.168.1.1 is the orbi router and 192.168.1.3 is the satellite - i installed these on Saturday i think and i changed the ds918 to 192.168.1.7 (and it is plugged into the router via ethernet) and changed port forwarding rules on the network settings page to allow remote access, everything worked fine locally and remotely.
today i changed my password which was the precursor to all my issues now.
hmm in my lan settings, i’ve changed starting ip to 192.168.1.1 from 192.168.1.3 - this lead to “port forward ruled enabled” notification on DSM.
i’ve restarted the plex app on the nas and am sending over fresh logs. hopefully that helped?Logs.zip (14.0 MB)
i’m sorry i missed that -
isp supplied the modem - orbi is plugged into that and the nas is plugged into the orbi. orbi satellite is in another room.
i am googling now how to check bridge mode - however i can say before satuday i using an old belkin router with no issues.
ubee ddm352.1
yea, only one port on the modem.
orbi is “netgear orbi voice RBK50V-1CCNAS”
everything was working fine locally and remotely prior to changing my plex password this afternoon
network interface>lan 1 connected
edit:
ipv4 tab
i do not have it set for DHCP
i have “use manual configuration”
ip address: 192.168.1.7
gateway 255.255.255.0
gateway: 192.168.1.1
dns server: 192.168.1.1
set default gateway checked
ipv6 tab:
auto
changed IPv6 to off.
exploring the router settings now
