Plex playback issue using wireless router
Recently I’ve bought a new router Asus RT-AC88u/AC3100 to extend my coverage (Dead zones) for my Plex server to stream through out my home.
But it seems to be causing Plex app to crash or stutter during playback on my Nvidia shield and Samsung Galaxy S7 and Tablet A10.1.
Because when I switch it back to my modems WiFi it work fine without stuttering during Direct play on Nvidia Shield or 20 mbps transcodes on my mobile devices.
Could this be related to port forwarding or any other technical issues?
Any help on this would be great.
Cheers.
You could get plex logs from the server and from the android app on the galaxy from using the two setups and we can then compare and see how requests are coming through to the server. I presume with the extra router you ended up with two subnets
So first ensure debug logging is enabled on the server
See https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
when you notice the problem, collect the logs from server and plex phone app
For server logs see
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
For plex android app log see
https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/ for how to email the logs to yourself
And then repeat the test without the extra router and capture the logs
It would best to do each of the two tests after a fresh relaunch of the plex media server
Plex Media Server Logs_2018-09-28_10-10-54.zip (1.5 MB) - Via router to mobile
Plex Media Server Logs_2018-09-28_10-17-32.zip (1.5 MB) Via Modem to mobile
Hope this helps.
Thanks for the logs. Looking at the two logs, it must be a networking issue and not a Plex issue
Playback is Direct Play so no PMS transcoding
Compare the KBytes/Second
Relevant Log Entries
Connected to Modem
Sep 28, 2018 10:16:40.744 [5192] DEBUG - Request: [192.168.1.3:59565 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (17 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:16:40.884 [15232] DEBUG - Request: [192.168.1.3:59566 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (18 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:16:40.888 [12820] DEBUG - Completed: [192.168.1.3:59566] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (18 live) TLS 4ms 2024 bytes (range: bytes=31426638394-)
Sep 28, 2018 10:16:40.897 [12820] DEBUG - Completed: [192.168.1.3:59565] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (18 live) TLS 154ms 917504 bytes (range: bytes=0-)
Sep 28, 2018 10:16:41.002 [8820] DEBUG - Request: [192.168.1.3:59567 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (19 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:17:23.125 [11496] DEBUG - Completed: [192.168.1.3:59567] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (19 live) TLS 42122ms 347602944 bytes (range: bytes=4854-)
Connected to Router
Sep 28, 2018 10:09:49.121 [7072] DEBUG - Request: [192.168.1.2:34174 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (12 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:09:49.684 [2724] DEBUG - Request: [192.168.1.2:34175 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (13 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:09:49.713 [14556] DEBUG - Completed: [192.168.1.2:34175] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (13 live) TLS 28ms 2024 bytes (range: bytes=31426638394-)
Sep 28, 2018 10:09:49.733 [14536] DEBUG - Completed: [192.168.1.2:34174] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (13 live) TLS 611ms 1179648 bytes (range: bytes=0-)
Sep 28, 2018 10:09:49.836 [11032] DEBUG - Request: [192.168.1.2:34176 (Subnet)] GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (14 live) TLS Signed-in Token (Strayan_Bass)
Sep 28, 2018 10:10:50.162 [14536] DEBUG - Completed: [192.168.1.2:34176] 200 GET /library/parts/39178/1534813587/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=209664 (16 live) TLS 60326ms 74907648 bytes (range: bytes=4854-)
And looking at the playback reporting to the server
Connected to Modem
Played 41.113 seconds with elapsed time in start/stop reporting being 41.271 seconds
Relevant Logs
Sep 28, 2018 10:16:41.841 [10016] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 0/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Sep 28, 2018 10:16:50.240 [3116] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 8224/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Sep 28, 2018 10:17:00.325 [8820] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 18221/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Sep 28, 2018 10:17:10.215 [12628] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 28223/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Sep 28, 2018 10:17:20.201 [7096] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 38220/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Sep 28, 2018 10:17:23.114 [7096] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state stopped, progress of 41133/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1978, metadataId=1368
Connected to Router
Played 20.460 seconds in 55.489 seconds elapsed
Relevant Logs
Sep 28, 2018 10:09:54.603 [2036] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 0/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:09:58.650 [11032] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 3873/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:09:59.978 [2724] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state buffering, progress of 5280/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:08.666 [7072] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 5280/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:18.660 [7072] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 11406/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:28.646 [2724] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 12840/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:38.645 [2724] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 18534/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:48.653 [2724] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state playing, progress of 20460/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
Sep 28, 2018 10:10:50.092 [7072] DEBUG - Client [fa06cab55348854e-com-plexapp-android] reporting timeline state stopped, progress of 20460/8039573ms for guid=com.plexapp.agents.imdb://tt5463162?lang=en, ratingKey=1368 url=, key=/library/metadata/1368, containerKey=/playQueues/1976, metadataId=1368
