Server Version#: 1.25.7.5604
Player Version#: 1.41.0.2876-e960c9ca
Plex player is stuck at the loading screen. Getting the following error from the logs:
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loaded extension GL_EXT_texture_norm16.
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loaded extension GL_EXT_color_buffer_half_float.
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loaded extension GL_EXT_disjoint_timer_query.
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loaded extension GL_ANGLE_translated_shader_source.
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: GL_*_swap_control extension missing.
Mar 16, 2022 22:16:29.896 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Testing FBO format rgba16f
Mar 16, 2022 22:16:29.897 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Using FBO format rgba16f.
Mar 16, 2022 22:16:29.897 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=0).
Mar 16, 2022 22:16:29.897 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: No advanced processing required. Enabling dumb mode.
Mar 16, 2022 22:16:29.897 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loading hwdec driver 'd3d11-egl'
Mar 16, 2022 22:16:29.902 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loading hwdec driver 'dxva2-egl'
Mar 16, 2022 22:16:29.916 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loading hwdec driver 'dxva2-dxinterop'
Mar 16, 2022 22:16:29.916 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loading failed.
Mar 16, 2022 22:16:29.916 [10316] DEBUG - [MPVEngine/mpv] libmpv_render: Loading hwdec driver 'cuda-nvdec'
Mar 16, 2022 22:16:29.916 [10316] DEBUG - [MPVEngine/mpv] libmpv_render/cuda-nvdec: Failed to load CUDA symbols
Not sure what’ going on, since I don’t have an Nvidia GPU installed.
