For me I avoid the HD-MA 7.1 channel audio, use 5.1 channel audio
I’m not convinced that is the problem as I do have 4K Videos that play fine using TrueHD 7.1.
Avengers: Endgame: TrueHD 7.1 doesn’t play on my 65"
Captain Marvel: AC3 5.1 doesn’t play on my 65"
Guardians of the Galaxy: TrueHD 7.1 plays fine on my 65"
John Wick 1, 2, & 3: TrueHD 7.1 all play fine on my 65"
An update…I just tried an Amazon Fire Stick 4K with the Plex app and both Avengers: Endgame and Captain Marvel played flawlessly on my 65"! From the looks of it we have an LG WebOS/Plex compatibility issue or the issue resides squarely with the WebOS version.
Are they 10bit or 8bit, I am convinced
All of them are 10 bit including the ones that work and the ones that don’t.
I have a brand new 2019 60" LG smart tv, I was looking for a solution to stream 4K HDR video’s I download, but now I see this is a problem its a good job as I was just about to shell out for lifetime plex plus for the media server.
I hope this gets sorted soon.
Same Issue on my 2019 LG NanoCell (LG 75SM9070, WebOS v04.70.04, LG Plex App v2.1.3, Aug.21st, 2019).
Here is the mediainfo of a file that can’t play fine (do the upper left little square garbage with the sound playing fine) :
Format : Matroska
Format version : Version 4 / Version 2
File size : 52.4 GiB
Duration : 1 h 37 min
Overall bit rate mode : Variable
Overall bit rate : 77.1 Mb/s
Encoded date : UTC 2019-12-08 22:11:14
Writing application : mkvmerge v33.1.0 ('Primrose') 64-bit
Writing library : libebml v1.3.7 + libmatroska v1.5.0
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 71.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.362
Stream size : 48.8 GiB (93%)
Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1003 cd/m2
Maximum Frame-Average Light Level : 145 cd/m2```
