Player Version#: 2.21.0.914-4839cbf2
Mac OS 10.14
MacBook Pro 13" 2017
I just installed the player, first it starts and crashes immediately, then it starts, the player window appears and just a black screen appears, no Plex logo and nothing else
I tried remove the player app complete incl. libraries etc, I installed older versions, always the same …
I repaired permissions
Onyx ran
pmphelper.log
2018-11-03 20:21:43 [ DEBUG ] HelperMain.cpp @ 50 - Helper ( “2.21.0.914-4839cbf2” ) up and running
2018-11-03 20:21:43 [ DEBUG ] CrashUploader.cpp @ 159 - Scanning: “/Users/markusrebl/Library/Caches/Plex Media Player/crashdumps/incoming” for crashdumps.
2018-11-03 20:21:43 [ DEBUG ] CrashUploader.cpp @ 169 - Scanning: “/Users/markusrebl/Library/Caches/Plex Media Player/crashdumps/incoming/2.21.0-4839cbf2”
2018-11-03 20:21:43 [ INFO ] LocalJsonServer.cpp @ 33 - Listening to socket: “/tmp/pmp_pmpHelper_markusrebl.sock”
2018-11-03 20:21:44 [ DEBUG ] HelperSocket.cpp @ 35 - Server connected.
2018-11-03 20:21:45 [ DEBUG ] HelperSocket.cpp @ 64 - Updating clientID.
2018-11-03 20:21:52 [ DEBUG ] HelperSocket.cpp @ 46 - PMP application quit, let’s wait 3 minutes and then exit
Plex Media Player.log
2018-11-03 20:21:43 [ INFO ] Log.cpp @ 115 - Starting Plex Media Player version: 2.21.0.914-4839cbf2 build date: 2018-10-23
2018-11-03 20:21:43 [ INFO ] Log.cpp @ 116 - Running on: macOS 10.14 [18.0.0] arch x86_64
2018-11-03 20:21:43 [ INFO ] Log.cpp @ 117 - Qt Version: 5.9.5 [x86_64-little_endian-lp64]
2018-11-03 20:21:43 [ DEBUG ] UpdateManager.cpp @ 45 - No Update directory found, exiting
2018-11-03 20:21:43 [ ERROR ] SettingsComponent.cpp @ 236 - Could not read config file.
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: settings inited
2018-11-03 20:21:43 [ DEBUG ] HTTPServer.cpp @ 32 - Listening to port: 32433
2018-11-03 20:21:43 [ INFO ] InputMapping.cpp @ 113 - Loading inputmaps from: “:/inputmaps”
2018-11-03 20:21:43 [ WARN ] InputMapping.cpp @ 92 - Missing element ‘idmatcher’ from mapping file: “:/inputmaps/dualshock4-xbox-emulate.json”
2018-11-03 20:21:43 [ INFO ] InputMapping.cpp @ 113 - Loading inputmaps from: “/Users/markusrebl/Library/Application Support/Plex Media Player/inputmaps”
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: Keyboard
2018-11-03 20:21:43 [ INFO ] LocalJsonServer.cpp @ 33 - Listening to socket: “/tmp/pmp_inputSocket_markusrebl.sock”
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: socket
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: roku
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: AppleRemote
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: AppleMediaKeys
2018-11-03 20:21:43 [ INFO ] InputSDL.cpp @ 207 - SDL found 0 joysticks
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: SDL
2018-11-03 20:21:43 [ INFO ] InputCEC.cpp @ 112 - libCEC was successfully initialized, found version 262146
2018-11-03 20:21:43 [ INFO ] InputComponent.cpp @ 54 - Successfully inited input: CEC
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: input inited
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: system inited
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 20 - “DisplayManager found 1 Display(s).”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 26 - “Available modes for Display #0 (Display 0)”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 0: 2560 x 1600 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 1: 1280 x 800 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 2: 2880 x 1800 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 3: 2048 x 1280 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 4: 1650 x 1050 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 5: 1440 x 900 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 6: 1152 x 720 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 7: 1024 x 768 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 8: 840 x 524 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 9: 800 x 600 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 30 - “Mode 10: 640 x 480 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] DisplayManager.cpp @ 40 - “DisplayManager : Current Display Mode on Display #0 is 2880 x 1800 x 32bpp @60Hz”
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: display inited
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: updater inited
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: remote inited
2018-11-03 20:21:43 [ DEBUG ] SettingsComponent.cpp @ 140 - Updated possible values for: “device” to (QVariant(QVariantMap, QMap((“title”, QVariant(QString, “Autoselect device”))(“value”, QVariant(QString, “auto”)))), QVariant(QVariantMap, QMap((“title”, QVariant(QString, “Built-in Output”))(“value”, QVariant(QString, “coreaudio/AppleHDAEngineOutput:1F,3,0,1,1:0”)))))
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 927 - Audio devices removed: QSet()
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 928 - Audio devices added: QSet(“coreaudio/AppleHDAEngineOutput:1F,3,0,1,1:0”, “auto”)
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 929 - Audio device selected: “auto”
2018-11-03 20:21:43 [ INFO ] PlayerComponent.cpp @ 1084 - Audio Config - device: auto, channel layout: auto, passthrough codecs: none, ac3 transcoding: no
2018-11-03 20:21:43 [ INFO ] PlayerComponent.cpp @ 1221 - Codec “mpeg2video” present
2018-11-03 20:21:43 [ INFO ] PlayerComponent.cpp @ 1221 - Codec “vc1” present
2018-11-03 20:21:43 [ INFO ] PlayerComponent.cpp @ 225 - Present codecs: png apng mjpeg thp gif dirac ffv1 ffvhuff huffyuv rawvideo ayuv r210 v210 v210x v308 v408 v410 y41p yuv4 ansi alac flac vorbis opus pcm_f32be pcm_f32le pcm_f64be pcm_f64le pcm_lxf pcm_s16be pcm_s16be_planar pcm_s16le pcm_s16le_planar pcm_s24be pcm_s24le pcm_s24le_planar pcm_s32be pcm_s32le pcm_s32le_planar pcm_s8 pcm_s8_planar pcm_u16be pcm_u16le pcm_u24be pcm_u24le pcm_u32be pcm_u32le pcm_u8 pcm_alaw pcm_mulaw 012v aac_at eac3_at eac3_eae truehd_eae mlp_eae eac3_eae(enc)
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: player inited
2018-11-03 20:21:43 [ INFO ] ComponentManager.cpp @ 41 - Component: power inited
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: switch mapped to DisplayComponent::switchCommand
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 264 - Host command maps to method with an argument.
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: recreateRpiUI mapped to DisplayManagerOSX::resetRendering
2018-11-03 20:21:43 [ ERROR ] InputComponent.cpp @ 273 - Slot for host command missing, or has incorrect signature!
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: player mapped to PlayerComponent::userCommand
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: poweroff mapped to PowerComponent::PowerOff
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 269 - Host command maps to method without arguments.
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: reboot mapped to PowerComponent::Reboot
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: suspend mapped to PowerComponent::Suspend
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: cycle_setting mapped to SettingsComponent::cycleSettingCommand
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: set_setting mapped to SettingsComponent::setSettingCommand
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: crash! mapped to SystemComponent::crashApp
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: script mapped to SystemComponent::runUserScript
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: message mapped to SystemComponent::hostMessage
2018-11-03 20:21:43 [ DEBUG ] SettingsComponent.cpp @ 783 - ()
2018-11-03 20:21:43 [ DEBUG ] HelperLauncher.cpp @ 52 - Connecting to helper
2018-11-03 20:21:43 [ DEBUG ] HelperLauncher.cpp @ 100 - Failed to connect to helper: “QLocalSocket::connectToServer: Connection refused”
2018-11-03 20:21:43 [ DEBUG ] HelperLauncher.cpp @ 158 - Launching helper: “/Applications/Plex Media Player.app/Contents/MacOS/…/Resources/PMP Helper”
2018-11-03 20:21:43 [ DEBUG ] HelperLaunchd.cpp @ 123 - Unloading helper
2018-11-03 20:21:43 [ INFO ] HelperLaunchd.cpp @ 29 - Ran launchctl successfully
2018-11-03 20:21:43 [ DEBUG ] HelperLaunchd.cpp @ 111 - Loading helper
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: close mapped to KonvergoWindow::close
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: toggleDebug mapped to KonvergoWindow::toggleDebug
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: reload mapped to KonvergoWindow::reloadWeb
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: fullscreen mapped to KonvergoWindow::toggleFullscreen
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: minimize mapped to KonvergoWindow::minimizeWindow
2018-11-03 20:21:43 [ DEBUG ] InputComponent.cpp @ 255 - Adding host command: switchMode mapped to KonvergoWindow::toggleWebMode
2018-11-03 20:21:43 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “lastUsedScreen” in section: “state” but it can’t be found
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 198 - Window state when saving geometry: QWindow::Visibility(Hidden)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 209 - Saving window geometry: QRect(80,90 1280x720)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 497 - QWindow visibility set to QWindow::Visibility(Windowed)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 614 - resize event: QSize(1280, 720)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 276 - Restoring geo: QRect(80,90 1280x720)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 198 - Window state when saving geometry: QWindow::Visibility(Windowed)
2018-11-03 20:21:43 [ DEBUG ] KonvergoWindow.cpp @ 703 - Screen 0 QScreen(0x6000001cd7a0, name=“Color LCD”) QRect(0,0 1440x900) QRect(0,0 1440x900) active: true selected: false
2018-11-03 20:21:43 [ DEBUG ] SettingsComponent.cpp @ 140 - Updated possible values for: “forceFSScreen” to (QVariant(QVariantMap, QMap((“title”, QVariant(QString, “Auto”))(“value”, QVariant(QString, “”)))), QVariant(QVariantMap, QMap((“title”, QVariant(QString, “0,0 1439x899 (Color LCD) *”))(“value”, QVariant(QString, “Color LCD”)))))
2018-11-03 20:21:43 [ DEBUG ] SettingsComponent.cpp @ 775 - Using web-client URL: “file:////Applications/Plex Media Player.app/Contents/MacOS/…/Resources/web-client/desktop/index.html”
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: display to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: input to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: player to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: power to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: remote to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: settings to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: system to webchannel
2018-11-03 20:21:43 [ DEBUG ] ComponentManager.cpp @ 88 - Adding component: updater to webchannel
2018-11-03 20:21:43 [ INFO ] Log.cpp @ 91 - Setting log level to: “debug”
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: option --hwdec-preload was replaced with --opengl-hwdec-interop and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 928 - Audio devices added: QSet()
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: mpv 53a7eec © 2000-2017 mpv/MPlayer/mplayer2 projects
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: built on Wed Aug 30 05:14:14 PDT 2017
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: ffmpeg library versions:
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libavutil 55.62.100
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libavcodec 57.92.100
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libavformat 57.72.100
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libswscale 4.7.100
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libavfilter 6.84.101
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: libswresample 2.8.100
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: ffmpeg version: git-2017-06-28-97a6171-,97a6171-pmp-260
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Configuration: ./waf configure --prefix=/Volumes/CI-OSX/jenkins/konvergo-deps-codecs/BUILD_TAG/darwin-x86_64/output/konvergo-codecs-depends-darwin-x86_64-release-2603aad --enable-libmpv-shared --enable-static-build --disable-cplayer --disable-apple-remote --disable-libavdevice --disable-debug-build
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: List of enabled features: asm atomics avutil-content-light-level avutil-imgcpy-uc bsd-fstatfs build-date cocoa coreaudio cplugins cuda-hwaccel encoding fchmod gl gl-cocoa glob glob-posix gnuc iconv is_ffmpeg libass libass-osd libav libavcodec libdl libm libmpv-shared macos-touchbar nanosleep optimize osx-thread-name plain-gl posix posix-or-mingw posix-spawn pthreads shm static-build stdatomic termios uchardet videotoolbox-gl videotoolbox-hwaccel videotoolbox-hwaccel-old zlib
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘’ -> ‘/Users/markusrebl/Library/Application Support/Plex Media Player’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘encoding-profiles.conf’ -/-> ‘/Users/markusrebl/Library/Application Support/Plex Media Player/encoding-profiles.conf’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘mpv.conf’ -/-> ‘/Users/markusrebl/Library/Application Support/Plex Media Player/mpv.conf’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘config’ -/-> ‘/Users/markusrebl/Library/Application Support/Plex Media Player/config’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘input.conf’ -/-> ‘/Users/markusrebl/Library/Application Support/Plex Media Player/input.conf’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - osx: Exiting…
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘scripts’ -> ‘/Users/markusrebl/Library/Application Support/Plex Media Player/scripts’
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Run command: hook-add, flags=0, args=[on_load, 1, 0]
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Run command: hook-add, flags=0, args=[on_preloaded, 2, 0]
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/coreaudio: selected audio output device: Built-in Output (45)
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-exclusive=false -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-device=“auto” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: af-defaults=“lavrresample:normalize=yes:o=[surround_mix_level=1]” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-spdif="" -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-channels=“auto” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Run command: af, flags=0, args=[del, @ac3]
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Option af-del: item label @ac3 not found.
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: property ‘sub-text-font-size’ was replaced with ‘sub-font-size’ and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-font-size=32.000000 -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-text-font-size=32.000000 -> 1
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: property ‘sub-text-color’ was replaced with ‘sub-color’ and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-color="#EEEEEE" -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-text-color="#EEEEEE" -> 1
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: property ‘sub-text-border-color’ was replaced with ‘sub-border-color’ and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-border-color="#000000" -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-text-border-color="#000000" -> 1
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: property ‘sub-text-align-x’ was replaced with ‘sub-align-x’ and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-align-x=“center” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-text-align-x=“center” -> 1
2018-11-03 20:21:43 [ WARN ] PlayerComponent.cpp @ 597 - cplayer: Warning: property ‘sub-text-align-y’ was replaced with ‘sub-align-y’ and might be removed in the future.
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-align-y=“bottom” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sub-text-align-y=“bottom” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: video-sync=“audio” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: hwdec=“no” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: videotoolbox-format=“nv12” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: deinterlace=“no” -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: display-fps=0.000000 -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-delay=0.000000 -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: cache=76800 -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: video-unscaled=false -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: video-aspect="-1" -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: keepaspect=true -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: panscan=0.000000 -> 1
2018-11-03 20:21:43 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: vo=“opengl-cb” -> 1
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: GL_VERSION=‘4.1 INTEL-12.0.34’
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Detected desktop OpenGL 4.1.
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: GL_VENDOR=‘Intel Inc.’
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: GL_RENDERER=‘Intel® Iris™ Graphics 650’
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: GL_SHADING_LANGUAGE_VERSION=‘4.10’
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Loaded extension GL_APPLE_rgb_422.
2018-11-03 20:21:44 [ WARN ] PlayerComponent.cpp @ 597 - opengl-cb: Function glMPGetNativeDisplay from extension GL_MP_MPGetNativeDisplay not found.
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Testing FBO format rgba16
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Create FBO: 16x16 (16x16)
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Using FBO format rgba16.
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: No advanced processing required. Enabling dumb mode.
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Loading hwdec driver ‘videotoolbox’
2018-11-03 20:21:44 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: audio-device=“auto” -> 1
2018-11-03 20:21:44 [ DEBUG ] Log.cpp @ 29 - “qrc:/ui/webview.qml:166:onLoadingChanged: WebEngineLoadRequest starting: file:///Applications/Plex Media Player.app/Contents/Resources/web-client/desktop/index.html”
2018-11-03 20:21:44 [ DEBUG ] HelperLauncher.cpp @ 52 - Connecting to helper
2018-11-03 20:21:44 [ DEBUG ] HelperLauncher.cpp @ 148 - Connected to helper
2018-11-03 20:21:44 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “clientID” in section: “webclient” but it can’t be found
2018-11-03 20:21:44 [ DEBUG ] HelperLauncher.cpp @ 93 - Helper is running version: “2.21.0.914-4839cbf2”
2018-11-03 20:21:45 [ DEBUG ] Log.cpp @ 29 - “qrc:/ui/webview.qml:170:onLoadingChanged: WebEngineLoadRequest success: file:///Applications/Plex Media Player.app/Contents/Resources/web-client/desktop/index.html”
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “clientID” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ DEBUG ] RemoteComponent.cpp @ 116 - Resolving system name: Host name: “Markuss MacBook Pro”
2018-11-03 20:21:45 [ DEBUG ] RemoteComponent.cpp @ 117 - Resolving system name: System name setting: “PlexMediaPlayer”
2018-11-03 20:21:45 [ DEBUG ] RemoteComponent.cpp @ 118 - Resolving system name: Is system name setting empty value: false
2018-11-03 20:21:45 [ DEBUG ] RemoteComponent.cpp @ 119 - Resolving system name: Is system name setting default value: true
2018-11-03 20:21:45 [ DEBUG ] RemoteComponent.cpp @ 120 - Resolving system name: Final value: “Markuss MacBook Pro”
2018-11-03 20:21:45 [ DEBUG ] SystemComponent.cpp @ 333 - “Web-client (3.71.1) fully inited.”
2018-11-03 20:21:45 [ INFO ] JS: %cmyPlexAccessToken is not in BasicVolatileStorage
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “settingsv2” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “users” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “anonymousClientID” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “skipSignIn” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ INFO ] JS: %c[appModelInitializer] Failed to read clientID from storage
2018-11-03 20:21:45 [ INFO ] JS: %c[appModelInitializer] Generating new clientID [ia2oxz69q1ri9vll6ufvfgvi]
2018-11-03 20:21:45 [ INFO ] JS: %c[appModelInitializer] Failed to read anonymousClientID from storage
2018-11-03 20:21:45 [ INFO ] JS: %c[appModelInitializer] Generating new anonymousClientID [qn1fc0sdw38uslbv8435cow2]
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “experience” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “deviceSettings” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “myPlexAccessToken” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ INFO ] JS: %c[UserManager] autoLogin false
2018-11-03 20:21:45 [ INFO ] JS: %c[Servers] Initializing…
2018-11-03 20:21:45 [ INFO ] JS: %c[Servers] Waiting for initial servers = [Loopback], plex.tv
2018-11-03 20:21:45 [ INFO ] JS: %c[Primary Server] Waiting to set the primary server
2018-11-03 20:21:45 [ INFO ] JS: %c[Primary Server] Waiting for any owned server to connect
2018-11-03 20:21:45 [ INFO ] JS: %c[Commands] Executing testServerConnection
2018-11-03 20:21:45 [ INFO ] JS: %c[Companion] No companion found
2018-11-03 20:21:45 [ INFO ] JS: %c[Servers] Finished initialization
2018-11-03 20:21:45 [ INFO ] JS: %c[Providers] Initializing…
2018-11-03 20:21:45 [ INFO ] JS: %c[Providers] Finished initialization
2018-11-03 20:21:45 [ WARN ] SettingsSection.cpp @ 82 - Looking for value: “sessionstats” in section: “webclient” but it can’t be found
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] Testing connection for [Loopback] at http://127.0.0.1:32400/media/providers
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] Testing legacy connection for [Loopback] at http://127.0.0.1:32400
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] Testing connection for plex.tv at https://plex.tv/monitoring/health
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] [Loopback] is unavailable at http://127.0.0.1:32400/media/providers (Status 0)
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] All connections to [Loopback] failed
2018-11-03 20:21:45 [ INFO ] JS: %c[Servers] Waiting for initial servers = plex.tv
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] plex.tv connected at https://plex.tv/monitoring/health
2018-11-03 20:21:45 [ INFO ] JS: %c[Connections] Active connection to plex.tv is https://plex.tv
2018-11-03 20:21:45 [ INFO ] JS: %c[User] tokenPromise failed
2018-11-03 20:21:45 [ INFO ] JS: %c[Servers] Found all servers = plex.tv
2018-11-03 20:21:45 [ INFO ] JS: %c[Primary Server] Waiting for any eligible server to connect
2018-11-03 20:21:45 [ INFO ] JS: %c[Metrics] Updating session last interaction time
2018-11-03 20:21:47 [ INFO ] JS: %c[Companion] No companion found
2018-11-03 20:21:52 [ DEBUG ] KonvergoWindow.cpp @ 198 - Window state when saving geometry: QWindow::Visibility(Windowed)
2018-11-03 20:21:52 [ DEBUG ] KonvergoWindow.cpp @ 209 - Saving window geometry: QRect(80,90 1280x720)
2018-11-03 20:21:52 [ DEBUG ] KonvergoWindow.cpp @ 497 - QWindow visibility set to QWindow::Visibility(Hidden)
2018-11-03 20:21:52 [ DEBUG ] KonvergoWindow.cpp @ 614 - resize event: QSize(1280, 720)
2018-11-03 20:21:52 [ DEBUG ] KonvergoWindow.cpp @ 198 - Window state when saving geometry: QWindow::Visibility(Hidden)
