Server Version#: 1.19.5.3112
Player Version#: Plex-1.15.0.1354-d31489f0
Plex app on Mac updated automatically, but failed to load. Icon keeps bouncing till it tells me its unresponsive, given it over 10 minutes to see if it was doing anything in the background. I deleted the old app, and tried to delete anything else that was leftover with CleanMyMac in an attempt to do a fresh install. But nothing works. I had the same issue yesterday when trying to install the player version before this (release date 13 july, dont know the version number).
Not really sure what to do, and don’t really feel as a paying customer its up to me to dive in deep to solve this issue.
Running MacOs 10.15.5
Plex Server is running on Ubuntu and works fine. So I am not looking to uninstall the server part, just the player part. Indeed I am talking about Plex for Mac, sorry about the confusion
All correct. I have my settings in MacOS set to allow apps downloaded from Appstore and Identified Developers. That setting leads to the prompt if I indeed really wanna open the app, so i click on open.
Then what happens, the Plex App Icon starts bouncing up and down in the dock, like it should when an app opens on Mac Os. That goes on for roughly 2 minutes, then the bouncing stops, a right click on the icon tells me its not responding and I have the option to force quit
I would try to follow SE56’s advice to remove any maybe-leftover files. I’d look at the uninstall instructions for Plex.app here first:
The client apps are close kin to the server, and if you aren’t using PMS on that machine, it can’t hurt to remove anything that might be left over. @SE56’s suggestion to look for server-related files is valid.
Ok, following the first like, I had a look, the Plex folder was already gone from " ```
~/Library/Application Support/ "
I rebooted, checked again searching the system for anything with PLEX in the name… Nothing. Redownloaded the app from the website, unzipped it, dragged it to Applications Folder and opened it. Still same issue.
Correct, server is running Ubuntu. Plex works perfectly fine on iPad, iPhone. Webbased works, though it for some reason wants to transcode which my server absolutely cannot do, but I wont pollute this topic with that. I use Xplay on LG Web Os, also works without a glitch. So Im 100% sure this is a Mac Os related problem.
