Plex was updated on the TV and now when I select media to play it sits in a loop of waiting (similar to buffering) until manual intervention (press play).
TV: TCL C835
Server Version#: 1.31.0.6654
Player Version#: 9.16.2.38.789 (3cad3f43)
Logs:
02-25 14:36:30.164 i: [ASS][Renderer] Attempting to start renderer from setSurface.
02-25 14:36:30.172 w: [ASS][Renderer] Missing video size, can't start renderer yet.
02-25 14:36:30.175 i: [FFmpeg] [INFO] Input #0, matroska,webm, from '':
02-25 14:36:30.185 i: [FFmpeg] [INFO] Metadata:
02-25 14:36:30.185 i: [FFmpeg] [INFO] ENCODER :
02-25 14:36:30.186 i: [FFmpeg] [INFO] Lavf58.76.100
02-25 14:36:30.187 i: [FFmpeg] [INFO] Duration:
02-25 14:36:30.202 i: [FFmpeg] [INFO] 00:29:23.26
02-25 14:36:30.206 i: [FFmpeg] [INFO] , start:
02-25 14:36:30.207 i: [FFmpeg] [INFO] 0.000000
02-25 14:36:30.210 i: [FFmpeg] [INFO] , bitrate:
02-25 14:36:30.213 i: [FFmpeg] [INFO] 1488 kb/s
02-25 14:36:30.226 i: [FFmpeg] [INFO]
02-25 14:36:30.232 i: [FFmpeg] [INFO] Stream #0:0
02-25 14:36:30.241 i: [FFmpeg] [INFO] (eng)
02-25 14:36:30.248 i: [FFmpeg] [INFO] : Video: hevc, none(tv, bt709, progressive), 1920x960
02-25 14:36:30.254 i: [FFmpeg] [INFO] , SAR 1:1 DAR 2:1
02-25 14:36:30.257 i: [FFmpeg] [INFO] ,
02-25 14:36:30.263 i: [FFmpeg] [INFO] 23.98 fps,
02-25 14:36:30.271 i: [FFmpeg] [INFO] 23.98 tbr,
02-25 14:36:30.273 i: [FFmpeg] [INFO] 1k tbn
02-25 14:36:30.274 i: [FFmpeg] [INFO] (default)
02-25 14:36:30.277 i: [FFmpeg] [INFO]
02-25 14:36:30.277 i: [FFmpeg] [INFO] Metadata:
02-25 14:36:30.278 i: [FFmpeg] [INFO] ENCODER :
02-25 14:36:30.280 i: [FFmpeg] [INFO] Lavc58.134.100 libx265
02-25 14:36:30.285 i: [FFmpeg] [INFO]
02-25 14:36:30.288 i: [FFmpeg] [INFO] DURATION :
02-25 14:36:30.290 i: [FFmpeg] [INFO] 00:29:23.262000000
02-25 14:36:30.291 i: [FFmpeg] [INFO]
02-25 14:36:30.293 i: [FFmpeg] [INFO] Stream #0:1
02-25 14:36:30.294 i: [FFmpeg] [INFO] (eng)
02-25 14:36:30.295 i: [FFmpeg] [INFO] : Audio: eac3, 48000 Hz, 5.1(side), s16p
02-25 14:36:30.297 i: [FFmpeg] [INFO] (default)
02-25 14:36:30.300 i: [FFmpeg] [INFO]
02-25 14:36:30.301 i: [FFmpeg] [INFO] Metadata:
02-25 14:36:30.311 i: [FFmpeg] [INFO] DURATION :
02-25 14:36:30.316 i: [FFmpeg] [INFO] 00:29:23.264000000
02-25 14:36:30.318 i: [FFmpeg] [INFO]
02-25 14:36:30.324 i: [FFmpeg] [INFO] Stream #0:2
02-25 14:36:30.330 i: [FFmpeg] [INFO] (eng)
02-25 14:36:30.336 i: [FFmpeg] [INFO] : Subtitle: ass
02-25 14:36:30.337 i: [FFmpeg] [INFO] (default)
02-25 14:36:30.341 i: [FFmpeg] [INFO]
02-25 14:36:30.346 i: [FFmpeg] [INFO] Metadata:
02-25 14:36:30.349 i: [FFmpeg] [INFO] title :
02-25 14:36:30.352 i: [FFmpeg] [INFO] English
02-25 14:36:30.355 i: [FFmpeg] [INFO]
02-25 14:36:30.357 i: [FFmpeg] [INFO] ENCODER :
02-25 14:36:30.358 i: [FFmpeg] [INFO] Lavc58.134.100 ssa
02-25 14:36:30.360 i: [FFmpeg] [INFO]
02-25 14:36:30.362 i: [FFmpeg] [INFO] DURATION :
02-25 14:36:30.367 i: [FFmpeg] [INFO] 00:28:18.699000000
02-25 14:36:30.371 i: [FFmpeg] [INFO]
02-25 14:36:30.374 i: [FFmpeg] [INFO] [FFmpegExtractor] Created filter for hevc.
02-25 14:36:30.376 i: [FFmpegExtractor] Container: Container[mkv] No Title - 1.5 Mbps, 29 minutes [CT: 0us, ST: 0us, SRT: -9223372036854775808us]..
02-25 14:36:30.379 i: [FFmpegExtractor] Track found: VideoStream[0-hevc] 1920x960 [SAR 1:1, DAR 2:1]. H.265 / HEVC (High Efficiency Video Coding) - Unknown Profile (video/hevc), ~1.5 Mbps -54 seconds 23.98fps, No Title / English (eng), 1 / 2420 bytes, Default ..
02-25 14:36:30.387 i: [FFmpegExtractor] Track found: AudioStream[1-eac3] 6 channels over 1551 (5.1(side)), 48000 Hz, 0,0 padding. ATSC A/52B (AC-3, E-AC-3) - Unknown Profile (audio/eac3), ~1.5 Mbps -54 seconds 0.00fps, No Title / English (eng), 0 bytes, Default ..
02-25 14:36:30.391 i: [FFmpegExtractor] Track found: SubtitleStream[2-ass] ASS (Advanced SSA) subtitle - Unknown Profile (text/x-ssa), ~1.5 Mbps 29 minutes 0.00fps, English / English (eng), 1 / 576 bytes, Default ..
02-25 14:36:30.393 i: [ExoPlayer][EventLogger] timeline [eventTime=0.96, mediaPos=0.00, window=0, period=0, periodCount=1, windowCount=1, reason=SOURCE_UPDATE
02-25 14:36:30.395 i: [ExoPlayer][EventLogger] period [1763.26]
02-25 14:36:30.396 i: [ExoPlayer][EventLogger] window [1763.26, seekable=true, dynamic=false]
02-25 14:36:30.400 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.403 i: [Player][ExoPlayer] onTimelineChanged (Position: 0 ms, Duration: 1763264 ms)
02-25 14:36:30.420 i: [LoadControl] Assumed Bitrate: 10000, Segment Count: 1171
02-25 14:36:30.422 i: [LoadControl] Setting buffer size to 73.19 MB / 405 seconds.
02-25 14:36:30.430 i: [FFmpeg] [INFO] [ASS] libass API version: 0x1600000
02-25 14:36:30.440 i: [FFmpeg] [INFO] [ASS] libass source: tarball: 0.16.0
02-25 14:36:30.443 i: [ExoPlayer][EventLogger] videoEnabled [eventTime=1.00, mediaPos=0.00, window=0, period=0]
02-25 14:36:30.445 i: [ExoPlayer][EventLogger] audioEnabled [eventTime=1.00, mediaPos=0.00, window=0, period=0]
02-25 14:36:30.453 i: [ASS][Renderer] Enabled renderer.
02-25 14:36:30.459 i: [FFmpeg] [INFO] [ASS] Raster: FreeType 2.12.1
02-25 14:36:30.460 i: [FFmpeg] [INFO] [ASS] Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 4.2.1 (COMPLEX)
02-25 14:36:30.461 i: [FFmpeg] [INFO] [ASS] Initialized
02-25 14:36:30.463 i: [FFmpeg] [INFO] [ASS][Decoder] Decoder has been initialised.
02-25 14:36:30.474 i: [ASS][Renderer] Attempting to start renderer from onEnable.
02-25 14:36:30.474 w: [ASS][Renderer] Missing video size, can't start renderer yet.
02-25 14:36:30.483 i: [FFmpeg] [INFO] [ASS] Using font provider fontconfig
02-25 14:36:30.489 i: [ExoPlayer][EventLogger] tracks [eventTime=1.05, mediaPos=0.00, window=0, period=0
02-25 14:36:30.492 i: [ExoPlayer][EventLogger] group [
02-25 14:36:30.493 i: [ExoPlayer][EventLogger] [X] Track:0, id=0, mimeType=video/hevc, codecs=hevc, res=1920x960, fps=23.976025, supported=YES
02-25 14:36:30.494 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.494 i: [ExoPlayer][EventLogger] group [
02-25 14:36:30.495 i: [ExoPlayer][EventLogger] [X] Track:0, id=1, mimeType=audio/eac3, bitrate=0, codecs=eac3, channels=6, sample_rate=48000, language=english, selectionFlags=[forced], supported=YES
02-25 14:36:30.496 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.507 i: [ExoPlayer][EventLogger] group [
02-25 14:36:30.509 i: [ExoPlayer][EventLogger] [X] Track:0, id=2, mimeType=text/x-ssa, language=en, selectionFlags=[forced], supported=YES
02-25 14:36:30.509 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.510 i: [ExoPlayer][EventLogger] Metadata [
02-25 14:36:30.510 i: [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 2447 bytes)
02-25 14:36:30.511 i: [ExoPlayer][EventLogger] scantype_progressive: (Value: 1 Buffer: 0 bytes)
02-25 14:36:30.512 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.516 i: [ExoPlayer][EventLogger] ]
02-25 14:36:30.520 i: [Player][ExoPlayer] Track information has been changed.
02-25 14:36:30.522 i: [Player][ExoPlayer] Setting initial track selection...
02-25 14:36:30.526 i: [TrackSelectorHelper] Initialising (Video: 1, Audio: 1, Text: 1)
02-25 14:36:30.526 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.527 i: [TrackSelectorHelper] Type: 1 Auto
02-25 14:36:30.529 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.531 i: [TrackSelectorHelper] Type: 1 Auto
02-25 14:36:30.537 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.540 i: [TrackSelectorHelper] Type: 3 Disabled
02-25 14:36:30.541 i: [TrackSelectorHelper] Type: 1 Auto
02-25 14:36:30.542 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.544 i: [TrackSelectorHelper] Type: 3 Disabled
02-25 14:36:30.545 i: [TrackSelectorHelper] Type: 1 Media Index: 1
02-25 14:36:30.553 i: [TrackSelectorHelper] Renderer: MediaCodecAudioRenderer Track: 0
02-25 14:36:30.554 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.558 i: [TrackSelectorHelper] Type: 3 Disabled
02-25 14:36:30.561 i: [TrackSelectorHelper] Override: audio/eac3 null english Indexes(0)
02-25 14:36:30.571 i: [TrackSelectorHelper] Type: 1 Media Index: 1
02-25 14:36:30.582 i: [TrackSelectorHelper] Renderer: MediaCodecAudioRenderer Track: 0
02-25 14:36:30.603 i: [TrackSelectorHelper] Type: 2 Auto
02-25 14:36:30.615 i: [TrackSelectorHelper] Type: 3 Media Index: 2
02-25 14:36:30.653 i: [TrackSelectorHelper] Renderer: Plex.Renderer.ASS Track: 0
02-25 14:36:30.672 i: [TrackSelectorHelper] Override: text/x-ssa null en Indexes(0)
02-25 14:36:30.719 i: [TrackSelectorHelper] Override: audio/eac3 null english Indexes(0)
02-25 14:36:30.730 i: [MediaCodecVideoSyncRenderer] Decoder initialised, after 0 attempts.
02-25 14:36:30.741 i: [ExoPlayer][EventLogger] videoDecoderInitialized [eventTime=1.30, mediaPos=0.00, window=0, period=0, OMX.MS.HEVC.Decoder]
02-25 14:36:30.759 i: [ExoPlayer][EventLogger] videoInputFormat [eventTime=1.33, mediaPos=0.00, window=0, period=0, id=0, mimeType=video/hevc, codecs=hevc, res=1920x960, fps=23.976025]
02-25 14:36:30.774 i: [ExoPlayer][EventLogger] audioInputFormat [eventTime=1.34, mediaPos=0.00, window=0, period=0, id=1, mimeType=audio/eac3, bitrate=0, codecs=eac3, channels=6, sample_rate=48000, language=english, selectionFlags=[forced]]
02-25 14:36:30.783 i: [TranscodeSession] Updating session status
02-25 14:36:30.784 i: [TranscodeSession] Direct Play
02-25 14:36:30.868 i: [FFmpeg] [INFO] [ASS] Event: [Script Info]
; Script generated by FFmpeg/Lavc58.134.100
ScriptType: v4.00+
PlayResX: 384
PlayResY: 288
ScaledBorderAndShadow: yes
[V4+ Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
Style: Default,Arial,16,&Hffffff,&Hffffff,&H0,&H0,0,0,0,0,100,100,0,0,1,1,0,2,10,10,10,0
[Events]
Format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text
02-25 14:36:30.888 i: [FFmpeg] [INFO] [ASS] Style format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
02-25 14:36:30.890 i: [FFmpeg] [INFO] [ASS] [0x79477680] Style: Default,Arial,16,&Hffffff,&Hffffff,&H0,&H0,0,0,0,0,100,100,0,0,1,1,0,2,10,10,10,0
02-25 14:36:30.893 i: [FFmpeg] [INFO] [ASS] Event format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text
02-25 14:36:30.967 i: [ExoPlayer][EventLogger] videoSize [eventTime=1.54, mediaPos=0.00, window=0, period=0, 1920, 960]
02-25 14:36:30.975 i: [ASS][Renderer] Attempting to start renderer from setVideoSize.
02-25 14:36:30.984 i: [Player] onDisplaySizeChanged(1920x960 at 0x0)
02-25 14:36:30.997 i: [Player][DimensionsLayout] Resizing: 1920 x 960
02-25 14:36:31.000 i: [FFmpeg] [INFO] [ASS][Renderer] Connecting surface ...
02-25 14:36:31.003 i: [ExoPlayer][EventLogger] renderedFirstFrame [eventTime=1.56, mediaPos=0.00, window=0, period=0, Surface(name=null)/@0xd0ac0aa]
02-25 14:36:31.004 i: [ExoPlayer][EventLogger] surfaceSize [eventTime=1.58, mediaPos=0.00, window=0, period=0, 1920, 960]
02-25 14:36:31.024 i: [ASS][Renderer] Renderer starting.
02-25 14:36:31.026 i: [FFmpeg] [INFO] [ASS][Renderer] EGL2 renderer created.
02-25 14:36:31.027 i: [FFmpeg] [INFO] [ASS][Decoder] Video size has been updated to 1920x960 (1.000000).
02-25 14:36:31.028 i: [FFmpeg] [INFO] [ASS][Decoder] Frame size has been updated to 1920x960.
02-25 14:36:31.434 i: [ExoPlayer][EventLogger] state [eventTime=1.98, mediaPos=0.00, window=0, period=0, READY]
02-25 14:36:31.441 i: [EngineEventManager] onBufferingEnded
02-25 14:36:56.471 e: [MetricsSender] Error posting metrics.
02-25 14:36:56.474 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:36:56.475 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
at okhttp3.internal.connection.RealConnection.connectSocket(SourceFile:147)
at okhttp3.internal.connection.RealConnection.connect(SourceFile:192)
at okhttp3.internal.connection.ExchangeFinder.findConnection(SourceFile:274)
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(SourceFile:1)
at okhttp3.internal.connection.ExchangeFinder.find(SourceFile:48)
at okhttp3.internal.connection.RealCall.initExchange$okhttp(SourceFile:32)
at okhttp3.internal.connection.ConnectInterceptor.intercept(SourceFile:12)
at okhttp3.internal.http.RealInterceptorChain.proceed(SourceFile:167)
at okhttp3.internal.cache.CacheInterceptor.intercept(SourceFile:192)
at okhttp3.internal.http.BridgeInterceptor.intercept(SourceFile:168)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(SourceFile:35)
at bi.a.intercept(SourceFile:50)
at okhttp3.logging.HttpLoggingInterceptor.intercept(SourceFile:4)
at com.plexapp.plex.net.u.intercept(SourceFile:355)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(SourceFile:114)
at okhttp3.internal.connection.RealCall.execute(SourceFile:28)
at ci.f$c.i(SourceFile:48)
at ci.f$c.f(Unknown Source:0)
at ci.h.invoke(Unknown Source:6)
at ci.f$c.g(SourceFile:107)
at ci.f$c.a(SourceFile:38)
at ci.j.run(SourceFile:1)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:462)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:307)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:302)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.lang.Thread.run(Thread.java:923)
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 36966) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
at libcore.io.IoBridge.isConnected(IoBridge.java:287)
at libcore.io.IoBridge.connectErrno(IoBridge.java:192)
at libcore.io.IoBridge.connect(IoBridge.java:134)
at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:142)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:228)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
at java.net.Socket.connect(Socket.java:621)
at okhttp3.internal.platform.Platform.connectSocket(Unknown Source:10)
at okhttp3.internal.connection.RealConnection.connectSocket(SourceFile:77)
... 33 more
Caused by: android.system.ErrnoException: isConnected failed: ECONNREFUSED (Connection refused)
at libcore.io.IoBridge.isConnected(IoBridge.java:274)
... 43 more
02-25 14:37:05.216 i: [HttpServer] /10.0.0.20:58725 - GET /logging
02-25 14:37:05.472 i: [HttpServer] /10.0.0.20:58726 - GET /favicon.ico
02-25 14:37:26.461 e: [MetricsSender] Error posting metrics.
02-25 14:37:26.464 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:37:26.467 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 36986) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
... 33 more
... 43 more
02-25 14:37:56.447 e: [MetricsSender] Error posting metrics.
02-25 14:37:56.450 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:37:56.451 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 36998) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
... 33 more
... 43 more
02-25 14:38:26.432 e: [MetricsSender] Error posting metrics.
02-25 14:38:26.435 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:38:26.436 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 37006) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
... 33 more
... 43 more
02-25 14:38:56.459 e: [MetricsSender] Error posting metrics.
02-25 14:38:56.462 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:38:56.465 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 37020) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
... 33 more
... 43 more
02-25 14:39:04.636 i: [HttpServer] /10.0.0.20:58741 - GET /logging
02-25 14:39:26.442 e: [MetricsSender] Error posting metrics.
02-25 14:39:26.448 e: An exception occurred: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
02-25 14:39:26.449 e: Stacktrace: java.net.ConnectException: Failed to connect to analytics.plex.tv/0.0.0.0:443
Caused by: java.net.ConnectException: failed to connect to localhost/127.0.0.1 (port 443) from /127.0.0.1 (port 37028) after 10000ms: isConnected failed: ECONNREFUSED (Connection refused)
... 33 more
... 43 more
02-25 14:39:33.414 i: [InteractionBehaviour] Woke up, reason: Key event detected.
02-25 14:39:33.415 i: [SystemUIBehaviour] Showing the system user-interface.
02-25 14:39:35.115 i: [Player][Hud][Video] Play clicked.
02-25 14:39:35.131 i: [ExoPlayer][EventLogger] playWhenReady [eventTime=185.70, mediaPos=0.00, window=0, period=0, true, USER_REQUEST]
02-25 14:39:35.132 i: [EngineEventManager] onBufferingEnded
02-25 14:39:35.133 i: [EngineEventManager] onPlaybackStarted: Delay-56762825
02-25 14:39:35.134 i: [MetricsLatencyBehaviour] Latency recorded for playback: 185779
02-25 14:39:35.160 i: [PlaybackTimeBehaviour] Initialising
02-25 14:39:35.163 i: [PlaybackTimeBehaviour] Starting stopwatch
02-25 14:39:35.164 i: [VideoAwakeBehaviour] Keep screen awake has been requested enabled for VideoAwakeBehaviour.
02-25 14:39:35.165 i: [AudioFocusBehaviour] Playback started
02-25 14:39:35.167 i: [VideoAwakeBehaviour] Keeping screen on
02-25 14:39:35.171 i: [AudioFocusBehaviour] Gained focus.
02-25 14:39:35.179 i: [TranscodeSession] Media choice updated
02-25 14:39:35.181 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: true
02-25 14:39:35.182 i: [PlayQueueBehaviour] Clearing audio PQ because video playback has started.
02-25 14:39:35.187 i: [Player][ExoPlayer] Passing subtitle offset of 0.
02-25 14:39:35.193 i: [DelayedPlayQueueBehaviour] Resolving Play Queue...
02-25 14:39:35.196 i: [DelayedRemotePlayQueue] Resolving delayed Play Queue...
02-25 14:39:35.201 i: [PlayQueueAPIHelperBase] No item path provided, will generate a new one
02-25 14:39:35.202 i: [WiFiLockBehaviour] Aquiring WiFi lock since playback was started.
02-25 14:39:35.219 i: [PictureInPictureBehaviour] Picture-in-picture is available and can be used.
02-25 14:39:35.253 i: Fetching [method:POST] https://10.0.0.140:32400/playQueues?includeChapters=1&continuous=1&includeLoudnessRamps=1&repeat=0&type=video&shuffle=0&uri=server%3A%2F%2Fab2eb66190ba415814c82a6f486d0182bfef5bfc%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F28448&key=%2Flibrary%2Fmetadata%2F28448&X-Plex-Token=...xzfG&X-Plex-Language=en-us
02-25 14:39:35.321 i: [MediaSessionBehaviour] Updating state to PLAYING
02-25 14:39:35.351 i: [TranscodeSession] Media choice updated
02-25 14:39:35.394 i: [TranscodeSession] Updating session status
02-25 14:39:35.404 i: [Player] onPlaybackStarted
02-25 14:39:35.406 i: [ExoPlayer][EventLogger] isPlaying [eventTime=185.95, mediaPos=0.00, window=0, period=0, true]
02-25 14:39:35.407 i: [TranscodeSession] Direct Play
