Plex Player - "Your connection to the server is not fast enough to stream this video."
@MwC_Trexx, do you still need logs and sample files? In this post with the link to the info from the Nvidia rep it sounded like Plex and Nvidia have already identified the problem with MP4 files, are able to reproduce it, and are working towards the fix:
All this technical stuff is interesting but all I can say is I am on Fire TV, I get this issue on both mkv and mp4 files and it is intermittent. I don’t think anyone has this problem when watching plex on the computer where the server is. I know I don’t. Therefore, the problem really should be in the server’s inability to communicate to the apps or vice versa. We get regular updates to the server but I don’t know when the last time apps updated.
@rwoffice Yes. While Plex has an idea of the cause, the more samples and logs they have to work with the better.
Fair enough, more information is always better I suppose :slight_smile:
Logs sent via DM/PM.
Thanks will try and look st them today.
log files sent via DM/PM
I dug through my logs and nothing stuck out. I hope the devs/ninja’s can see something.
Plex Media Server Logs_2019-02-21_13-40-41.zip (5.6 MB)
Server Logs
Quoting someone from another chat:
I played around with it a little bit last night with my HET server and OVH server, they performed pretty similarly. In plex for AppleTV and Shield (including Kodi with plex plugin on shield and MrMc on Shield) according to glances on my servers it would cap out almost perfectly at 50Mbps. It is almost think the shield experience 7.2.2 has some bug related to pings above certain threshold capping download speed. The plex apps are whatever, and this may lead me to believe there is no actual issue with plex app on shield but with 7.2.2 network drivers. Because emby had same issue for me on shield with both servers
So this sort of leaves me with the conclusion that plex app on appletv = borked, shield network drivers 7.2.2 borked. Everything else not borked. I get instant loads from both servers 100Mbps files on PMP windows.
I had the same exact experience !!!
But why is it that all my Android phones are also affected with this issue? I still think it’s the Plex client.
In looking at your logs briefly, there are lot of issues I see.
  1. I would update to the newest version of PMS that was just released as there were some mac fixes in it.
I am also seeing slow DB issues. Make sure you have done the usual library maintenance (optimize db, clean bundles, empty trash, etc.).
It could also be a sign that your Mac just isn’t fast enough for what you are trying to do (too much resource contention on storage/cpu/etc.).
605 Feb 21, 2019 13:18:53.232 [0x7000026f5000] WARN - SLOW QUERY: It took 290.000000 ms to retrieve 0 items.
3440 Feb 21, 2019 13:19:11.093 [0x700001e42000] WARN - SLOW QUERY: It took 610.000000 ms to retrieve 2 items.
3484 Feb 21, 2019 13:19:11.377 [0x700002672000] WARN - SLOW QUERY: It took 300.000000 ms to retrieve 1 items.
3486 Feb 21, 2019 13:19:11.382 [0x7000021d7000] WARN - SLOW QUERY: It took 210.000000 ms to retrieve 16 items.
3584 Feb 21, 2019 13:19:11.632 [0x700002d19000] WARN - SLOW QUERY: It took 310.000000 ms to retrieve 16 items.
3654 Feb 21, 2019 13:19:11.787 [0x700002901000] WARN - SLOW QUERY: It took 1140.000000 ms to retrieve 50 items.
3817 Feb 21, 2019 13:19:12.518 [0x700002778000] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 0 items.
I am seeing a lot of “garbage encoding issues” related to some of your files. I would say at least from just a quick skim, your media “quality” is most of your issue.
13713 Feb 21, 2019 13:29:53.432 [0x700000cdc000] WARN - Got a request to stop a transcode session without a session GUID (or with an invalid one).
13888 Feb 21, 2019 13:30:05.669 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13889 Feb 21, 2019 13:30:05.669 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13890 Feb 21, 2019 13:30:05.669 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
13899 Feb 21, 2019 13:30:05.674 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13900 Feb 21, 2019 13:30:05.674 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13901 Feb 21, 2019 13:30:05.674 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
13910 Feb 21, 2019 13:30:05.675 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13911 Feb 21, 2019 13:30:05.675 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13912 Feb 21, 2019 13:30:05.675 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
13915 Feb 21, 2019 13:30:05.676 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13916 Feb 21, 2019 13:30:05.676 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13917 Feb 21, 2019 13:30:05.676 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
13921 Feb 21, 2019 13:30:05.678 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13922 Feb 21, 2019 13:30:05.678 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13923 Feb 21, 2019 13:30:05.678 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
13935 Feb 21, 2019 13:30:05.679 [0x700002b90000] ERROR - [FFMPEG] - Error: cannot create compression session: -12908
13936 Feb 21, 2019 13:30:05.679 [0x700002b90000] ERROR - [FFMPEG] - Try -allow_sw 1. The hardware encoder may be busy, or not supported.
13937 Feb 21, 2019 13:30:05.679 [0x700002b90000] WARN - avcodec_open2 returned -542398533 for encoder 'h264_videotoolbox'
14067 Feb 21, 2019 13:30:09.239 [0x700002a8a000] DEBUG - Job running: EAE_ROOT='/var/folders/wf/y9f3z42d3_sd0fqv39n7trtr0000gn/T/pms-a2eb2cfd-4923-4da4-abe3-0ba0c2c2fed8/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/Users/angelicapullins/Library/Application\ Support/Plex\ Media\ Server/Codecs/a22632d-2034-darwin-x86_64/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder' '-codec:#0x100' 'mpeg2video' '-codec:#0x101' 'ac3' '-ss' '440' '-probesize' '10000000' '-i' '/Volumes/WD My Book AV 1020 Media/Recorded TV/The View (1997)/Season 22/The View (1997) - S22E108 - Episode 108.ts' '-filter_complex' '[0:#0x100]scale=w=720:h=406[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-filter_complex' '[0:#0x101] aresample=async=1:ocl='\''stereo'\'':osr=48000:rematrix_maxval=10.000000dB[2]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '21' '-maxrate:0' '1724k' '-bufsize:0' '3448k' '-r:0' '59.939999999999998' '-preset:0' 'veryfast' '-x264opts:0' 'subme=2:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none' '-force_key_frames:0' 'expr:gte(t,442+n_forced*8)' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac_at' '-b:1' '162k' '-segment_format' 'mpegts' '-f' 'ssegment' '-individual_header_trailer' '0' '-segment_time' '8' '-segment_start_number' '55' '-segment_copyts' '1' '-segment_time_delta' '0.0625' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/54D813EF-08C0-4391-95DA-FA1AE8B6DC8C/d0cfe4f2-2a3b-4fcb-81d1-1e22872b2a95/seglist?X-Plex-Http-Pipeline=infinite' '-segment_list_type' 'csv' '-segment_list_size' '2147483647' '-segment_list_separate_stream_times' '1' '-max_delay' '5000000' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'media-%05d.ts' '-start_at_zero' '-copyts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/54D813EF-08C0-4391-95DA-FA1AE8B6DC8C/d0cfe4f2-2a3b-4fcb-81d1-1e22872b2a95/progress'
14114 Feb 21, 2019 13:30:09.664 [0x700000d5f000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] invalid coupling range (8 >= 7)
14116 Feb 21, 2019 13:30:09.666 [0x700002f25000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] error decoding the audio block
14170 Feb 21, 2019 13:30:09.964 [0x700001f48000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] frame sync error
14171 Feb 21, 2019 13:30:09.966 [0x7000020d1000] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
14172 Feb 21, 2019 13:30:09.974 [0x700002c96000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] frame sync error
14173 Feb 21, 2019 13:30:09.975 [0x700002fa8000] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
14639 Feb 21, 2019 13:30:32.863 [0x700001f48000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] exponent 25 is out-of-range
14640 Feb 21, 2019 13:30:32.864 [0x700002c13000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] error decoding the audio block
14641 Feb 21, 2019 13:30:32.868 [0x700002b90000] ERROR - [Transcoder] [ac3 @ 0x7fa1dc829c00] frame sync error
I would probably remux them through something like mkvtoolnix, handbrake, etc.
Do you still need more logs for this issue or has the problem been identified?
The last update I had from the devs was they are working on some caching changes that they hope should improve things. I don’t have any eta on when that might be released though.
I am experiencing the same issue with all HEVC (H.265) streaming on both Fire TV and Fire Stick regardless of the resolution (480P/1080P). In some cases the video will buffer for a few minutes, give the “Your connection is too slow” error message, then play normally, while other times it never stops pausing. This is on a local gigabit network (confirmed via pcap that traffic is not hitting the proxy) with a dual-core Xeon server. Older H.264 movies seem to work fine.
Plex Media Server Logs_2019-03-11_21-32-53.zip (2.8 MB)
I have a 1st GEN Fire TV. After the recent PLEX upgrade on my Fire TV I began getting the Server Not Fast Enough Message followed by intermittent stuttering during playback. I went into settings and tried several combinations. In the end the only thing I needed to change was to reduce the H.264 level from 4 to 3.2 and the issues stopped. Good Luck!
did that change force it to transcode?
I am seeing the client disconnect errors in your logs, but without the corresponding clients logs from that same session, the server logs themselves don’t really tell us anything.
11448 Mar 11, 2019 21:26:21.970 [0x7fbcb9bfb700] DEBUG - Request: [192.168.0.115:37972 (Subnet)] GET /library/parts/47869/1547636091/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (14 live) TLS Signed-in Token (dmmartin13)
11449 Mar 11, 2019 21:26:21.979 [0x7fbcb9bfb700] DEBUG - Content-Length of /data/Video/Movies/Kids/KUNG_FU_PANDA_3.mp4 is 1465611918.
11450 Mar 11, 2019 21:26:22.026 [0x7fbcedbfe700] DEBUG - Failed to stream media, client probably disconnected after 1294336 bytes: 104 - Connection reset by peer
So where do we stand with this issue? I feel like if the Plex Devs still have issues clearly understanding the problem after a year - the company should just for a flight ticket to one of our houses and they can take all the logs they want. There are hundreds of people facing this issue.
Are there any Plex Devs even reading and responding to this forum thread?
Just adding myself to the list of people suffering from these problems on shield with local Plex server. Playback is fine on other local devices and even remotely. Glad the Nvidia forums had info on possible fixes soon. Keeping my fingers crossed. :crossed_fingers:
