Server Version#: 1.24.5.5173
Player Version#: 4.69.1
First time posting so I hope I’m doing it right. I’m frustrated and could use some guidance.
Burned 500 movies using both Handbrake and Make MKV. Followed the right naming convention (all movies are in a top level folder called “Movies”, each Movie has it’s TVDB or TMDB File Name followed in parens by the year, e.g. True Grit (2010). When I go to play some of the movies (seems to be more associated with Blu Ray movies) only the trailer plays. There are plenty of files in the folder and the naming convention follows this syntax: title_t00.mkv and goes through to title_t10.mkv.
Hi Plex Ninja -
First - THANKS a lot for responding. I will have to send the screenshot a bit later this evening. In the mean time here are some answers:
Q: What are the files named title_tXX.mkv and where are they located?
A: These are the native files that burned using Make MKV. taxonomically they are located as follows: /Movies /True Grit (2010)/ [then there are 11 files]
I think it is following the correct naming convention as most all of the other 500 movies I burned are working well. It seems to be two that I have checked (True Grit and No Country for Old Men) both seem to have problems.
While you’ve named the folder correctly, you haven’t completed the naming of the actual file .
From your screenshot, I can see file named title_t00.mkv is most likely the movie and the others are the extras.
On that basis,
Rename title_t00.mkv → True Grit (2010).mkv
For each of the other files, you must examine them and give them a descriptive filename and “extras” classification . Here are the options available to you.
Using one of mine as example (with the movie and ‘-scene’ clips,
-rw-r--r-- 1 chuck chuck 389020875 May 27 2018 'Creating the Virtual Jungle-behindthescenes.mkv'
-rw-r--r-- 1 chuck chuck 124442172 May 27 2018 'Boma Stampede-scene.mkv'
-rw-r--r-- 1 chuck chuck 153342009 May 27 2018 'Tarzan and Janes Unfailing Love-scene.mkv
-rw-r--r-- 1 chuck chuck 386322111 May 27 2018 'Tarzan Reborn-scene.mkv'
-rw-r--r-- 1 chuck chuck 133880516 May 27 2018 'Tarzan vs Akut-scene.mkv'
-rw-r--r-- 1 chuck chuck 11986842317 May 27 2018 'The Legend of Tarzan (2016).mkv'
-rw-r--r-- 1 chuck chuck 126207759 May 27 2018 'Train Ambush-scene.mkv'
