Thats imposible to do it with 6TB of movie and serials. Why is it on Windows Plex server working and on the Qnap Plex server not? This is obviously BUG you should FIX it. This is not only BUG for Czech rep. but also for Poland and Slovakia, do you know how milions people is it togetger?
I had to convert the subtitles into format UTF8-without BOM and its working fine. When converted into UTF8-with BOM subtitles are wrong if its helpfull.
I do not know, I have uninstlled Plex server on my windows, there was problem to run two servers on one network.
So, you can not do anything, we have convert all new subtitles forever. Where can I make a complain?
Having multiple servers on the same network should not be a problem
With above setup, then yes, or find better subs
If you where running the older legacy agents, then you could use a plugin I wrote that would update the subs for you, but as said, plugins doesn’t work with the newer native agents
I can have my team leader pop by this thread if you want, but as I see it, there’s nothing to complain about, since the article I linked to a few posts ago, clearly said to use utf-8
And I still fail to see why you could not use SubTitle Edit as I also mentioned, and converting an srt file does not take that long
We only support UTF-8 officially as mentioned. I can ask if others can be, but I can’t make any promises. Suggest making a feature request in our feature suggestion forum
Plex has a policy never ever to mess with user files!
As such, Plex will never ever replace your files.
It’s something you have to do yourself, or use 3rd.Party tools for
You dont have to touch files and still you can fix the subtitles, no? Im not genius but load subtitle into RAM memory, change subtitle only temporary in memory…
