Plex Re-adding a Deleted Library
Version 1.17.0.1709
I added a library
I decided to delete this libary and start from scratch.
Now when I try to add the library again, it like plex is skipping over all the files in the folder.
When I deleting the library showed had been named, but not everything had images yet.
Did you empty the trash, followed by Clean Bundles and maybe Optimize Database after the delete?
nvm fd it
and 4 others, since it moved with later versions of the WebClient
emptytrash
It not working here is the log
https://pastebin.com/ApL5m4UU
zip of all logs needed, since lots of agents are involved here
And LOL, an mnt named: /mnt/emby/TV :slight_smile:
Yeah I decided I wanted to give plex a try to.
Especially after I heard about hdr streaming being possible in the future. With some new technology that being developed.
This ended up fixing my issues
I was waiting to see if any issues came up, but every file works now. Include the Extras library I made.
Plex scanning seemed to go a lot slower then emby/jellyfin for the initial library scan.
However, I’m liking plex metadata controls, which makes it easier to switch bad matches. Also it automatically detects when I have multiple version of the same episode/movie
