Please do guide me on how to fix the issue. Remote access says available outside my network for a few seconds then suddenly not working. I am a beginner in Raspberry Pi, Linux and anything to do with media servers. It would be great if someone can show me a comprehensive guide to get this started? Really Appreciate it!
That really sounds like your port forwarding is not set up properly. Double check the settings on your router. Make sure you are forwarding to the static ip address of the pi and make sure the external and internal ports are 32400.
I have the same problem ‘Remote access says it is available outside my network for a few seconds in green and suddenly it turns red with the message that access outside my network is not available’
Before it worked for me, the problem occurs after an update of Plex today.
Ok so right now it’s 49.205.xxx.xxx:32400, hope this is sufficient. I am a little apprehensive about sharing the rest of the IP address. I hope that’s ok and you understand.
no, that’s fine. just wanted to make sure it wasn’t a private IP and you had some kind of double NAT situation. to be more specific though, i’m assuming you verified that you see that 49. ip within the router gui bound to the wan ip.
