Plex remote access wont connect
Hi im new to plex. I am having issues with getting my server to remote connect. It connects for a couple of seconds to a couple of minutes the it disconnects. Im using a asus rt-n66u. i have tried a lot of diffrent configuraton i have port forwarding enabled. I set up port triggering and made sure that upnp is enabled. I have also tried a vpn. the server has a static IP and windows firewall has been disabled. I called my isp to see if they where port blocking and the ports I was trying to use are open on there end. I have looked all over for a solution and I cant seem to find one.
