Plex Renaming Titles for Sort Order
Server Version#: 1.31.1.6716
Player Version#: 4.101.1
How do I stop Plex from renaming titles when I rescan a directory/folder???
I like my movies to show in the order of their title…For instance I want The Warriors under T, not W…so I went through all my files and manually the sort titles on movies that actually start with either “the” or “a”…
However, Plex, in it’s infinite wisdom, after rescanning after adding more files, decided to revert these titles back to being listed WITHOUT the sort title I manually entered…
If I want to sort my files this way, I should be able to do this, and over-ride their ridiculous need to revert back to this other way…
Is there a way to do this?..This really frustrates the ■■■■ out of me…all that work appears to have been for naught!!!
:face_with_symbols_over_mouth: :face_with_symbols_over_mouth: :face_with_symbols_over_mouth: :face_with_symbols_over_mouth: :face_with_symbols_over_mouth:
See: https://support.plex.tv/articles/201105343-advanced-hidden-server-settings/
Search for: ArticleStrings
Plex doesn’t change the Sort Title, if the field was “locked”.
The true culprit might be “Empty trash automatically after every scan”. Disable this.
