Server Version#: 1.21.1.3830
Player Version#: 4.47.3
Server no longer appears to add new tv shows to the library. I’ve been ripping my Pokemon DVDs and copied all the files to their new home on the plex server in the tv shows library, told plex server to scan the tv shows library and nothing.
It starts the scan, then a second or so later it finishes, when I check the logfiles, it has a lot of “Error issuing curl_easy_perform(handle)” in it, and “(7, Couldn’t connect to server) (Failed to connect to 127.0.0.1 port 32400: Address already in use)”.
I have stopped the plex server, waited a minute or 2, started it up again, i’ve checked ‘netstat’ (with various options) while plex is stopped and confirmed nothing is running on port 32400.
This appears to have only just started, I have shows from earlier this month showing just fine in my library (last appears to be from 18 days ago).
I updated Plex about a week ago from the previous version.
(File removed)
