Server Version#: 1.31.1.6733
After this last update, when I add new shows to my server and then select “Scan Library Files” the server starts the scan but then stops quickly and you do not see the directories scanning in the activity window like usual. Nothing updates. This is only in my TV directory, the Movies and Music update correctly. I have tried restarting the client, rebooting the server several times, and selecting the other scanner (Plex Series Scanner) in the TV library advanced settings. Curiously though, I cannot revert back to the “Plex TV Series” scanner as it gives me a “your changes could not be saved” message. Any ideas?
Could be a fried s server database… if so you should see some related error messages in your server logs or be able to identify using the procedure outlined in the database repair support article:
https://support.plex.tv/articles/repair-a-corrupted-database/
I did actually perform a database check with the SQLite app but is just said “OK”" so I figured that part was good to go. I would delete it all and start over but I do have over 150 playlists set up and do not want to loose them.
Only thing that fixed it was creating a new TV Library… Now the database won’t delete the old one so that’s great…
Sometimes it takes awhile to delete
Also make sure you unpin the deleted library. If you don’t it will appear to hang around even though it’s actually gone
