Plex sees correct channel -Guide lists different channel
something new in the past week or two i assume
in jacksonville florida Channel 25.1 is a ABC affiliate WJXX-HD. If i look in settings,manage channels its stated correctly
But in the guide its listed as WJGVCD (Gospel Vision TV) a religious channel and in turn reflects those shows but not the ABC content that is playing.
My local TVs reflect correctly as well as the channel guide on my Xbox.
This must be something to do with the Grace note interface.
Attempting to record winbleton this weekend…wont happen unless Resolved
You would need to delete and rebuild the DVR. You likely need to select a different provider in the guide dropdown during set up. ( this will not delete any scheduled recordings you have)
Deleted and rebuilt the DVR. No change.
It is a OTA setup.
Manage channels shows 25.1 WJXX-HD (ABC) -content is ABC (verified)
Guide shows 25.1 WJGV
I do notice 25.2 is correct Displays WJXX-DT2.
25.3 is correct WJXX-DT3
attempted again with a slightly different zip code and it seemed to have corrected itself. Hmm
Unfortunately different zip codes can result in different channel options. If you can provide the two zip codes that had incorrect channel data and the one that was correct we can try to report it to Gracenote.
32092 incorrect
32216 accurate
about 15 miles from each other
Thanks. Sent to one of the Employees that sends information to Gracenote. Unfortunately Gracenote doesn’t send Plex back notifications when things are fixed on their side.
This issue was filed with Gracenote today.
