Wrong channel shows in guide
The latest post closed in November 2018. But I am still having this problem.
Plex shows the correct station ID for in the DVR setup. But the guide is wrong and records the wrong channel when I schedule a recording. Have tried multiple zip codes without success. Also seems extreme to have to delete the DVR in order to simply change the zip code.
How do I get a guide that correctly matches the HD HomeRun and Plex DVR setup?
FINALLY found a zip code that gets the channels right.
Seems odd that HDHomeRun finds all of the right channel info but Plex cannot figure it out using the same zip code.
Maybe Plex can learn something from HDHomeRun.
Thanks for listening.
