Plex series
does not detect the series only works the movies. because when I have series plex does not detect them it says there are no files. emby if it detects
Plex Media Server version?
Please share a screenshot, directory listing, etc of how you have the TV shows named and organized.
  • Make sure you are using a TV library. No mixing movies and TV shows in the same library.
  • Plex is very picky with TV show file naming and organization. Make sure you are following Plex guidelines.
  • If you rename/reorganize a TV show, then Plex Dance the entire show.
In the end I got it. I did it like you told me. I named it exactly as it is. He’s too picky about names, plex. thanks
