Thanks for your help with this. Today it asked for my credentials again on all clients and then started working! Problem solved. Thanks for your time - reassuring to know you are there.
Matt
Matt
I think I may be having the same issue. On 1.22.x, everything works fine, but if I upgrade to 1.23.x, suddenly my server settings are unavailable. Downgrading back to 1.22.x resolves the issue. If this is unrelated, I can start a new thread with logs.
Edit: Sorry, upon more searching, I found this issue with the FreeSBD pkg and this fixes it. Sorry for the ping. Server settings unavailable - #82 by Volts
Has the issue investigation been completed? Can I expect the configuration with the new server (named after my PC) to remain stable, or will it at some point go back to the initial server name?
I am having the exact issue . Need a fix for this Windows 10 Server is no longer available
