Plex Server Desapearing or Apearing as two or more servers with or not same name
Server Version#: newest
Player Version#: newest
<no logging - only my findings>
Was not possible find any help in community to fix this situation.
Over and over when I log into server its apearing another server that cannot be connected and the one who is supposed to be working is not working too… or sometimes one of them are working but not exactly the propoer one.
This was killing me because all the time was affecting my experience and the server was not tracking wached movies etc.
First of all, you need to know that any update you have done, you need to restart de server because its not restarting services by itself (dumb). This also will avoid you to get no page when you try to access GUI interface (web).
Second, you need to check inside the server under setting/generals the path for your server data files… This is the point.
If you have in this path the right path for your server its ok, but you´ll need to delete any other path for server files that you have setted before (the others that is showing in your plex). Probably you´ll not see the path but by default is under Windows Users Accounts at:
“C:\Users<user_account>\AppData\Plex Media Server” → Delete entire plex folder
If you have changed the path inside plex to other place, check if that place has only the right server files or change the path in plex to the right one.
Once you have done the adjust deleting wrong files, correcting the path in plex, restart de server! not the Windows, Only Plex Server.
This will fix this issue!
C ya!
