Plex Server does not start on my Ds415Play Synology
Server Version#:Synology DS415Play
Player Version#: PlexMediaServer-1.23.0.4438-5eef0fd80-x86_DSM6.spk
Since the last update of the Plex server dated April 26, 2021 on my NAS Synology DS415Play, I cannot launch the server on the NAS. It starts updating and does not go to the end. It stops then and show the Launch button again as if nothing had been done.
I cannot then access my medias from any of my devices, the NAS server not being accessible.
I think this is a bug, as it was working well with the previous update.
Thanks for your help.
Others have reported same problem. Also issues on DS414 running DSM 7.
Plex is investigating.
@FordGuy61
@Coolmarin
I just reproduced the error on our lab DS214play (x86 – unfortunately).
I am working now to try and reproduce on any of our lab ARM systems.
Please hold tight. Please resist spawning new threads.
Update:
I was able to reproduce on a DS214play (Intel 32bit) and DS213j (ARMv7) with DSM 6.
When the build team is back in the office (they are in Europe), they will look at my findings.
For now, please continue to use the “Public” version.
Thanks. We have to wait, then and hope they will solve the issue at the soonest
Thanks for the update.
Appreciate the quick response. Know you’re busy with other stuff.
You should be able to fallback to the public version, 1.22.3.4392. I just installed it on my DS414.
It is still available at plex.tv/download if you turn off Plex Pass downloads.
I have some test builds. I’ve tested the X86 build and it works.
Please let me know.
I will try it tomorrow.
Be in touch.
Thanks.
Thanks ChuckPa.
It works. Well done.
Have a nice day
De nouveau opérationnel . Merci. Bonne journée
that works, thank you!
Works on my DS414. Thanks!
