Plex Server Not Authorized - Synology DSM7
I am unable to connect to my newly set up Synology NAS with Plex. The NAS is directly connected to my router via LAN. I was originally running the PMS beta from the package center, then uninstalled and did a manual install of the latest pkg from the website. Did the claim token and followed all of the other troubleshooting steps I could find on the forums, but I can’t figure it out. Any help would be appreciated, I’ve attached the plex logs for reference. Thanks.
Logs.zip (121.6 KB)
@cndc28
Are you attempting to open the server by using the Synology-provided button in Package Center ?
If so, and you have QuickConnect signed in, it won’t work. They changed something which is beyond our ability to set the URL.
The easiest way now is to open the NAS by direct http://ip.addr.of.syno:32400/web and then setting a toolbar bookmark.
Hi, yes that was it, thanks!
I might have found a way to work with this new “configuration” in PMS.
I won’t know until after Engineering has time to review it.
It seems to just work now. If I close plex and reopen it from the synology server it opens right up using the preconfigured URL.
Once Plex is properly signed in and setup, the Package Center link is fine.
It’s only during that initial setup , where you need it most, it misbehaves.
That’s what I’m working on with Engineering.
