Server Version#: 1.13.2.5154-fd05be322_amd64
Player Version#: Web Player
Hi all,
For a little while one of my two servers hasn’t been listing, looking at the chrome browser console (on win10) today I found this log item, which is odd as I’m signed in with my Plex account and further signed in using my personal user pin. I’ve seen in previous similar topics that running an SSH tunnel so you can almost get local access to the web page has been suggested, I’ve tried that and am encountering the same problem.
[Connections] HomeServ-J is unauthorized at http://127.0.0.1:9090 (Status 401)
onLogMessage @ main-1-7234a6396d00ac2d746d-plex-3.69.1-91b0591.js:3212
This issue (though perhaps not the log item as I didn’t check then) has been ongoing for some time, but just an FYI that just today I upgraded to this plex server version and subsequently changed the server IP and upgraded it to Ubuntu 18 from 16. …but again there was a problem before this, but this may have further complicated matters possibly.
Since port 9090 isn’t a Plex port, I’m uncertain why that port would be listed in your PMS logs and why PMS would be attempting to connect to it unless you have something on your system advertising itself as a player or IGD at that port.
Does this mean anything to you? Remind you of anything installed and running?
I assumed Guest mode was the new incognito as I no longer see incognito when I click on my avatar in chrome, sorry, just found it now, so will try again.
Hmm, ok I think my key idea might be right as it might be locked to the old internal IP (10.0.0.10) see the console log below… ps HomeServ-J is the local server on 192.168.0.10 (was 10.0.0.10).
[Servers] HomeServ-J was found through plex.tv
[Connections] Access token for HomeServ-J changed to b77rbk6K16ssLqrFwbFJ
[Connections] Testing all 1 connection(s) for HomeServ-J
[Connections] Added connection https://10-0-0-10.c63edda7b1464ecaa5aa03ef57756a35.plex.direct:32400 for HomeServ-J
[Connections] Testing connection for HomeServ-J at http://192.168.0.10:32400
[Connections] Testing connection for HomeServ-J at https://10-0-0-10.c63edda7b1464ecaa5aa03ef57756a35.plex.direct:32400
[Connections] HomeServ-J is unauthorized at http://192.168.0.10:32400 (Status 401)
[Connections] HomeServ-J is unavailable at https://10-0-0-10.c63edda7b1464ecaa5aa03ef57756a35.plex.direct:32400 (Status 0)
[Connections] Prevented fallback to insecure connection for HomeServ-J
[Connections] All connections to HomeServ-J failed
yep. Nail on the head. Youll need to get in it, knock down the connection to Plex.tv and reestablish.
If you aren’t sharing with many people, just blast the Preferences.xml and reclaim it as if cold (just don’t recreate library sections… those survive the soft reset).
If you are sharing with a lot, rename Preferences.xml then do copy/paste surgery on it, bringing the ID fields (Machine ID , processed machine ID, etc) forward into the new Preferences.xml.
The existing server instance records will need be deleted (general cleanup of Plex.tv)
Once you have ‘ownership’ again, we can see what it’s looking at.
I unfortunately really do need see the logs from PMS startup and where it connects to Plex.tv to see which adapters / IPs are being selected and reported to pinpoint what will resolve this permanently for you
