Plex Server not showing in Plex Client
Server Version#: 1.42.1.10060-720010060
Player Version#: Web
All devices are on the same LAN
Plex says it is running on the DiskStation Package Centre
I reset my Plex password (as you do:-) and disconnected all devices. Logging back into plex I cannot see my Synology NAS Plex server, I have updated it to the latest version and reboot the NAS, still nothing!
It is so long ago I set all this up but I cannot find any way to add the server back, any pointer please? Thanks, Peter
Thank you so much @ottoKerner Resolved:-). I did search for the solution before posting but maybe I used the wrong terms, thanks for the pointer, I learnt something too! Peter
I used this solution to re-add a deleted Synology NAS hosted plex server (my second) successfully, but it then disconnected my first. I can only keep one connected - when I re-add the other it disconnectd the one that was connected. Not sure how to troubleshoot this.
