Plex Server on Raspberry Pi: HD Homerun tuner not visible
Ive been running a plex server on my Mac for a while with live TV from an HD Homerun tuner and I decided to try setting up a Pi 3 as a server. The Plex software is installed and working and Ive been able to stream video but I dont see the tuner available in the Live TV settings menu. Is there a trick to getting it to show up?
Did you try to add your HD Homerunner manually?
How do you do that?
@epyonxero Please read the link I posted in my last reply and add the ip of your Homerun in step 2.
Ah, I missed the link. Thanks
