Plex Server will not refresh metadata no mater what
Server Version#: 1.15.6.1079
My Plex Server has begun regularly failing to grab metadata for both Shows and Movies. It’s not 100%, but it’s at least 50%. To make things worse, there seems to be nothing I can do to get it to refresh the metadata. Steps taken:
  1. Removed missing metadata movie
  2. Cleared /var/lib/plex/Plex Media Server/Plug-in Support/Caches
  3. Scan Library Files
  4. Emptied Trash
  5. Re-added movie
It is instantly added back with the same frame grab and empty metadata. Running “Refresh All Metadata” on the library furthermore seems to do nothing. Any help or suggestions would be much appreciated. I really don’t what to have to start from scratch to fix whatever is happening.
can you please share the file name (exactly as you have it) including extension.
If MP4, have you cleared out the metadata ?
Woke up today to the problem just being fixed… I went around and looked, all movies and shows that were lacking metadata suddenly have metadata after 2 days of not being able to get it to add metadata. I verified that the Plex Server hadn’t restarted, not sure why it finally fixed itself.
Windows 10
Plex Media Server Version 1.14.1.5488
What I have happening is somewhat similar.
I will get metadata for a while (a month let’s say),
Then it will stop and nothing I do gets it to pull in.
A week or so later, it mysteriously starts being pulled in again.
I can’t find a rhyme or reason to this, I just have to wait for it to start again.
I do wish that someone had an answer.
