Plex Server won’t load on iPadOS 15
Server Version#: 1.23.4.4805
Player Version#:7.20(449) beta
(Capabilities) Forgive me if this is the wrong place to post this. My Plex library will not load remotely from the beta version, or public release version on iPadOS running iOS 15 beta 2. I have the same issue on my iPhone running iOS 15 beta 2 I’ve noticed the following error when I load the app from my iPhone (error from the server log) - Platform ‘iOS’ not matched by plugin platform requirements. It works fine when on the same network, but it wont load remotely. I can access the server from my iPad on the web and it works just fine, only error is when using the app. Any advice?
Plex does not support Beta OS’s. I would suggest rolling back to iOS 14 if you need Plex working at the moment.
Sounds good - I just wanted y’all to be aware of the issue
We don’t tend to look at errors at this stage since the OS can change at any time so trying to resolve issues could get undone with the next update. Once iOS 15 is official, we can definitely take a look then.
