Plex shows all my content as unavailable, all permissions should be done correct, can anyone take a look at my logs?
Logs.zip (1.6 MB)
Logs.zip (1.6 MB)
Thank you for the logs. It helps a great deal to have the logs with the problem.
You do have a file permissions problem
Aug 29, 2020 21:39:10.521 [0x7ff943029700] ERROR - Couldn't check for the existence of file "/volume2/Download/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS.mkv": boost::filesystem::status: Permission denied: "/volume2/Download/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS.mkv"
Aug 29, 2020 21:39:10.521 [0x7ff943029700] ERROR - Error opening file '"/volume2/Download/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS/Dragonheart.Vengeance.2020.NORDiC.720p.BluRay.x264-RAPiDCOWS.mkv"' - Permission denied (13)
Depending on how files are copied (especially from windows), it’s not uncommon for user plex to have permission to read the file(s) lost as the files are copied.
Linux is very strict on permissions. You can see it but user plex can’t. That’s what’s happening here.
The first steps are:
plex as having permission.plex.a. Select and Right-Click the shared folder name
b. Go to the Permission tab
c. If user plex isn’t listed, Create the entry to allow READ.
d. Check the box to “Apply to this folder, sub-folders, and files”
e. Click OK and let it update the permissions.
f. When complete - go back to Plex and Scan Files again.
Thank alot for the fast answer.
It looks like plex already had permission in both the controle panel - shared folders and in file station, but i’m not sure that i’m in the right places, i also dont see the “Apply to this folder, sub-folders, and files” box that you have in your screenshot?
yes, you’re in the wrong place.
Shared Folder permissions are there – that part is right.
However, you need correct the individual file permissions.
FileStation - RightClick the desired share - Properties.
I’m pretty sure that what i’m doing ? but my “Edit Shared Folder” window does not look like yours ?
Do i have the right DSM version? DSM 6.2.3-25426 Update 2, it says its up to date
Maybe u should know i had this problem before, Plex can't find my media anymore
back then i used SSH to do something i dont remember and i cant see the posts from the guy who helped me back then. i also cant find the guide that i used.
maybe that has something to do with why mine looks diffrent that yours? just a wild guess
What I am showing you is pure DSM 6.2.2
Should this fail, there is a way to do it via SSH but that’s pretty hard core / low level.
I can direct you through that if needed
Thats what i have been doing, but when i get to step 5. it looks like this:
I tried to make a new shared folder to test, at step 5. i get the same “edit shared folder” as u show in your screenshot, and when i put content in the folder and add it in plex library, plex finds it like before. the question is why my old shared folders dont have the same “edit shared folder” pop up ![]()
OK, so that worked, again, you were the one helping last time too, but it kinda annoys me that i cant do it the “right” way, no idea why i cant ? im sure next time i run into the problem i will have forgotten how to do it again
also thanks for the advise , ill try out “filebot”
Thanks for the help both of you, i appreciate you take the time to help
Yea i will write it down this time
