Updated my plex app on my sinology naz now everything saying unavailable when I look in the directory all media is there and can be watched out of plex but plex won’t allow it attached are my logs
Non of my files are in the shared folder so don’t understand
No on a separate directory called “stv plex” and I might be being stupid but doubt understand what’s been said on the first reply
Thanks.
I see what is happening.
In your logs, I find:
May 28, 2019 20:45:24.573 [0x7f18e5bb7700] ERROR - Couldn't check for the existence of file "/volume2/STV PLEX/music/.grab": boost::filesystem::status: Permission denied: "/volume2/STV PLEX/music/.grab"
May 28, 2019 20:45:24.573 [0x7f18e5bb7700] ERROR - Couldn't check for the existence of file "/volume2/STV PLEX/tv/.grab": boost::filesystem::status: Permission denied: "/volume2/STV PLEX/tv/.grab
User Plex (which is how Plex works on Synology), must be given permission to access that folder. It is a “Shared Folder” by Synology’s definition.
In Control Panel - Shared Folders,
Look for STV PLEX and click it
Now click the EDIT button
You will now see the details popup open.
Click the Permissions tab.
There you will see user Plex listed on the left side.
On that line, Click the R/W box.
This gives user Plex permission to write to the STV PLEX folder on Volume 2.
Save this change.
Now, for any other folders you created this way, you must perform the same steps.
You may select “Read Only” or “Read/Write”.
Thank you very much that sorted it and written in a way anyone can understand your a star
